Old 04-29-2021, 08:50 AM   #1
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Best head intake option
Current just a gpi ss4nfc in a l99 but planning on buying a 416 block and going centri. But really want to do heads intake before all of that and would like to know the better choice..
Looking into a used Maxx effort set from gpi (don't know price yet), prc 260, trickflow 255 or just stock ported heads
Intake will either be xod1x or stock ported, or ls7
CHRI55 is offline   Reply With Quote
Old 04-29-2021, 10:11 AM   #2
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
I have the gpi max kit and i will vouch for their heads. They are a work of art and are massive. They flow
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 04-29-2021, 01:54 PM   #3
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Thx. What all comes with the package
Old 04-29-2021, 02:15 PM   #4
gunchamp
gunchamp's Avatar
The max package was complete. Everything you need to do the entire top. Cam, intake, heads, lifters, gaskets, bolts ect. Its not cheap, but it makes power and sounds amazing!
Old 04-29-2021, 02:15 PM   #5
gunchamp
gunchamp's Avatar
Old 04-29-2021, 02:16 PM   #6
gunchamp
gunchamp's Avatar
Theres mine with the full kit. Cold start and idle
Old 04-29-2021, 02:58 PM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Your money is better spend going towards that Centri first, You'll never need heads unless you plan to go wild and serious racing. Stock heads can make a ton of power with FI
Greenhornet2 is offline   Reply With Quote
Old 04-29-2021, 03:24 PM   #8
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Originally Posted by Greenhornet2 View Post
Your money is better spend going towards that Centri first, You'll never need heads unless you plan to wild and serious racing. Stock heads can make a ton of power with FI
That what I was really thinking about but don't have the funds to go centri yet. At least not a new kit plus fueling. Was probably going to stay in na for a while since I'm in the process for moving too
Old 04-29-2021, 04:21 PM   #9
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
I see. They out of stock too lol
Old 04-29-2021, 10:43 PM   #10
Rmkuper
Rmkuper's Avatar
Drives: 2010 Camaro SS
What wheel tire setup is that?
Sent from my SM-F916U using Tapatalk
Rmkuper is offline   Reply With Quote
Old 04-30-2021, 08:00 AM   #11
Greenhornet2
Whats the heads cam intake kit going to cost? Can't be too much less than a supercharger. As far as fueling get good injectors, $1000 and you will get away with just a voltage booster or a ZL1 pump to get you more power than the heads//cam kit will get you. You can wait to upgrade that later. Of course do what you like to do, but bang for your buck FI is the way to go. I can tune on 100 octane for 800whp on a PD. Where I am at now is about all I want though, for the street. Stock heads except for the spring upgrade when I did the cam. I was at 600WHP with just the whipple and ZL1 pump with 1050 injectors..
Old 04-30-2021, 08:23 AM   #12
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
This!!!! I have stock heads, intake, and TB. I've got probably 800hp at the crank. Mods in sig.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-30-2021, 08:52 AM   #13
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
I see you have 3 91s how does it work with the gear
Old 04-30-2021, 08:54 AM   #14
CHRI55
Streetkingz_chri55
CHRI55's Avatar
Drives: 2012 2ss/rs
Yea in looking into the ess g3x kit now
