05-07-2021, 06:22 PM | #1 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
ZL1 AUX Trans Cooler
Anyone here that has 13-15 M6 ZL1. Can you take a picture of the front lower radiator? Looking to see if the M6 cars have the aux trans cooler. GM says its only the auto cars that have the aux trans cooler.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
05-07-2021, 08:31 PM | #2 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I believe that only the auto ZL1 has the aux cooler
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
05-18-2021, 01:49 PM | #3 |
Just looking for a picture of a manual ZL1 car to confirm.
2010 LS3 2SS/RS M6
05-18-2021, 08:32 PM | #4 |
I'll check out my service manual.
05-23-2021, 03:47 PM | #5 |
Let me know what you find out.
2010 LS3 2SS/RS M6
05-29-2021, 04:36 PM | #6 |
I didn't forget about ya!
I looked in my 2014 Camaro service manual, here are some pics that show the aux cooler. This pic shows the actual cooler. The service manual doesn't say if it is used with either trans. The next two pics show the the service manual calling out the LSA Camaro (ZL1) trans cooler lines. Notice they only go into the radiator which is similar to the Z/28 and SS. This picture shows something I found while researching the ZL1 Aux cooler myself a few months ago. It shows the 6 speed trans with an obvious aux transmission fluid cooler. So with all that info above, I cannot say for sure that only the auto ZL1 comes with an aux cooler that is mounted in front of the radiator. I guess you still need to lay eyes on a ZL1 with the 6 speed manual.
05-29-2021, 04:37 PM | #7 |
Sorry the pics are turned, damn iphone!
05-31-2021, 08:24 AM | #8 |
I have all the pipes that GM says a maual car need so when they get here i guess we will see. Thanks for the pictures, the first set of pictures look as if its the auto trans.
2010 LS3 2SS/RS M6
07-23-2021, 08:40 PM | #9 | |
Drives: 2013 BRM ZL1 Camaro M6 Join Date: Feb 2014
I have just replaced my clutch and don't have any good photos, but I used glove finger tips and rubber bands to reduce the mess, as in this other member's post https://www.camaro5.com/forums/showthread.php?t=400884 |
07-25-2021, 05:14 PM | #10 |
Drives: 2013 ZL1 Join Date: Mar 2013
I think I can solve your question. The lines and cooler you are seeing goes to the rear axle to cool the fluid in it, not your transmission. All ZL1's have this and the transmission being a auto or a stick it does not matter. GM did this because the ZL1 really was designed for track use and the rear axle fluid was getting hot
07-25-2021, 09:31 PM | #11 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
08-13-2021, 07:06 AM | #12 | |
2010 LS3 2SS/RS M6
08-13-2021, 08:14 AM | #13 |
08-13-2021, 09:17 PM | #14 |
