Old 05-10-2021, 11:16 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Oil Pan (bell housing) Torque Specs
I've done some searching and can't find an answer for a V8 LS3 engine, just a V6.
Does any have the full torque spec of the oil pan and also the two 15m bolts from the bell housing to the oil pan?
thanks!
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 05-11-2021, 07:05 AM   #2
Rmkuper
Rmkuper's Avatar
Drives: 2010 Camaro SS
thanks!
I06 inch lbs the rest are 18ft lbs.
Sent from my SM-F916U using Tapatalk
Rmkuper is offline   Reply With Quote
Old 05-11-2021, 07:13 AM   #3
Rmkuper
Rmkuper's Avatar
thanks!
Could not fond the bell housing for some reason but I just didn't not to long ago i believe they were 37ft lbs.
Old 05-11-2021, 12:57 PM   #4
dma05
dma05's Avatar
Thanks for the info! 😁
Allen
2011 Camaro 2SS/RS
Old 05-11-2021, 08:28 PM   #5
Rmkuper
Rmkuper's Avatar
Word of advice use a paint pen on those last 2 that are inch lbs. As a reminder. I got carried away torqueing 18 ft lbs when I got to those I just kept going and pop broke a bolt.
Old 05-12-2021, 01:07 AM   #6
dma05
dma05's Avatar
Is there a sequence to follow for the oil pan bolts?
thanks!
Allen
2011 Camaro 2SS/RS
Old 05-12-2021, 06:56 AM   #7
Rmkuper
Rmkuper's Avatar
Don't think so.
Old 05-12-2021, 07:33 AM   #8
Rmkuper
Rmkuper's Avatar
Fyi.. note step 3 at the bottom of you removed it.
Old 05-13-2021, 09:30 AM   #9
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
Same happen to me...I was just about to stop and "snap"
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 05-13-2021, 10:49 AM   #10
Rmkuper
Rmkuper's Avatar
Worst feeling ever. Did you get it out? I left mine in if it starts to leak to bad I will try to get it. I have heard of it eventually working its way out.
Old 05-13-2021, 12:26 PM   #11
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Torque on the oil pan bolts isnt critical. Dont over tighten. Thats where you will find trouble. Snug them down and call it a day
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
