![]() Drives: 2012 Camaro 1LS Join Date: Apr 2021
2012 V6 exhaust pipe size
I plan on getting a dual exhaust cutout for my car. Yes I am aware that it's going to sound horrible. I want it to be placed behind my resonator. I have been seeing mixed results online when people ask for the size of the exhaust, some say 2.5 and others say 2.25. What is the size right behind the resonator?
V6 is 2.25... The V8's are 2.50.
![]() Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
My last 2012 RS V6 I installed 2.5" behind the axle. they should be 2.25 from the factory.
BOOST OR BUST
+1
Based on my own experience, V6 is 2.25" stock pipes.. unless 2012 specs are different than the 2010 models. I used to have an MRT V2 Axle-back Exhaust and I had to blow out the stock piping slightly in order to connect it with my 2.5" ARH long system.
Batmaro=The Bane of My Existence ⠀⠀⠀⠀⠀ ⠀ ⠀⠀⠀⠀⠀⠀ ⠀ ⠀ ⠀⠀⠀ ⬋LIKE AND FOLLOW THE BUILD ON INSTAGRAM⬊
BUILD STATUS: LOADING BOOST . . . |
Far as I know, if after the h-pipe it should be 2.25 but between the cats and h-pipe it is 2.5 like the V8. So technically both sizes are correct, just depends where exactly in the exhaust. It drops to 2.25 coming out the h-pipe, so where you’re talking after the resonators it should be 2.25
