07-28-2021, 04:20 PM | #1 |
Drives: 1997 30th conv & 2012 45th conv Join Date: Jul 2017
Thicking noise on restored engine and low oil pressure
I have rebuilt my L99 engine. Removed AFM but kept VVT and installed Comp cam kit stage 1 for this setup (the kit included hydraulic rollers, springs and pushrods etc). Link: https://www.summitracing.com/parts/cca-mk189-301-13
I also installed a Melling high volume pump for better oil pressure. I Kept original valve tray with reducer valve. After reading that some said to plug and other said not to plug. After rebuilt everything I started the engine for first time this evening and got two questions: 1. After running the engine for about 20 minutes, there is a ticking sound that seems to come from the cylinder head covers (lifters?). Sounds like the same as from mechanic lifters. Since there are no adjustments on this kit it, I guess the lifters not have got enough oil pressure yet? So how long will it take to get full pressure in the lifters? Or any other ideas what makes the sound and what to do? 2. I was hoping that Mellings HV oil pump and removing the AFM had bring more oil pressure but on idle 500 rpm I only have about 15 psi with hot engine (5-30 oil). At 2000 rpm I have 50 psi. I have read in other post that some also have low pressure and lowest pressure regarding GM spec are 6 psi! Any ideas why so low oil pressure on idle on a new rebuild engine with Melling HV? Can it be the valve train pressure relief valve that I didn't plug? |
07-28-2021, 04:26 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Lets hope Comp Cams has their heat treatment figured out. There were a lot of early cam failures on here when I first joined in 2017 with Comp cams.
07-28-2021, 07:30 PM | #3 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
07-29-2021, 12:51 AM | #4 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
Timing chain, or clearance issues were my first thoughts. Post a video..
07-29-2021, 02:37 AM | #5 |
Here is a video with the engine noise: https://youtu.be/WgK9ID66zrQ
Ticking engine noise Camaro 2012 L99 with restored L99-engine with AFM delete but VVT running and COMP Cams MK189-301-13 - COMP Cams Stage 1 LST Master Camshaft Packages installed (hydralic lifters). Kit https://www.summitracing.com/parts/cca-mk189-301-13 Car have run about 20 minutes with hot engine on idle (oil 5-30) but still ticking noise (lifters?). Exhaust not installed. |
07-29-2021, 02:44 AM | #6 |
Also a video on my oil pressure: https://youtu.be/ilu_Hqi2sDs
Varies from about 15 psi at idle (500 rpm), 30 psi at 1000 rpm and 50 psi at 2000 rpm. All with hot engine running for about 20 minutes. All engine parts new, Melling high volume pump installed. original L99 valvetrain with high pressure reduce valve left and not plugged. Last edited by aaberg; 07-29-2021 at 08:30 AM. |
07-29-2021, 04:20 AM | #7 | |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
07-29-2021, 07:06 AM | #8 |
I agree on the tick, nothing I would be worried about.
07-29-2021, 07:39 AM | #9 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
That is plenty of oil pressure
07-30-2021, 06:04 PM | #10 |
Drives: 15SS Camaro Join Date: Dec 2020
If you go back in check the cam bearing clearances, usually the culprit with low oil pressure issues because no one considers them during a refresh. Because of where they are in relation to the valve train the lifters get very noisy. Seen this over and over.
07-30-2021, 09:45 PM | #11 |
Honestly man it sounds just fine to me. Your pressure seems to be just fine also. Don’t sweat it unless it becomes a problem.
07-31-2021, 12:56 AM | #12 |
Thank you all for confirming there is no ploblems with ticking or oil pressure!
07-31-2021, 01:36 AM | #13 |
Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
sounds normal to me. ofc when you rebuild something paranoia sometimes takes a hold lol.
07-31-2021, 03:02 AM | #14 |
Yes, better to be safe than sorry
Tags |
l99, lifter noise, low oil pressure, thicking noise |
