08-25-2021, 09:16 AM | #1 |
Drives: 2019 Camaro ZL1 2004 Pontiac GTO Join Date: Feb 2018
WTB complete SS strut assemblies for my Z/28
After much debate I have decided to convert my 2015 Z/28 to a DD. I want to replace all four strut assemblies with SS compatible units. I do not want used ones so I am not inquiring in the used parts section. I want new complete assemblies. GM does not sell the complete strut assemblies at least I cannot find a part number for them. So that leaves me with aftermarket assemblies. I have found many examples on Ebay and such websites. I was just wondering if somebody in the know could direct me to the best examples to purchase. Remember I want NEW COMPLETE assemblies SS configuration only. I have had very good luck with Monroe units that are on my GTO. If I don't get any better recommendations I will probably go with Monroe. I have also already purchased SS front and rear sway bars as I intend to replace those also as they will match the SS springs. The Z/28 components will be saved if and when I ever sell the car they will go with. Any help is much appreciated. Thanks.
08-25-2021, 11:21 AM | #2 |
Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
Not sure if they have complete units with springs, but Monroe OESpectrum Premium struts have identical etch tags and stamping on the bodies that my originals had. I wasn’t able to find a single difference in them. Hope this helps
08-25-2021, 12:42 PM | #3 |
Yes thanks I was leaning toward Monroe anyway. They do have complete assemblies .
08-25-2021, 01:39 PM | #4 |
Drives: 2013 1SS Join Date: Dec 2012
08-25-2021, 01:44 PM | #5 |
Drives: 2015 2ss Join Date: Jun 2009
might be a long shot but give NicKey Performance in Rockford, IL a call. they may have something to assist you with (since they're not too far from ya).
let them know Anthony sent ya http://www.nickeyperformance.com/contact
2015 Camaro 2ss, NicKey Performance built/tuned |
08-25-2021, 02:08 PM | #6 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Try Rock Auto
Orange Krush II
08-25-2021, 02:37 PM | #7 | |
08-26-2021, 09:14 AM | #8 |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
Any reason why you dont keep the DSSV for DD services?
08-26-2021, 10:18 AM | #9 |
Drives: 1969 Z/28 + 2015 Z/28 Join Date: Aug 2009
I know we all buy our cars for our own reasons which is fine. I bought a Z/28 because I wanted a Z/28 and what it stood for. I believe others may buy a Z/28 because they want to buy a bad ass 427 cu in small block Camaro, which I really don't blame them. To each their own, but it doesn't make sense to me to change out integral parts of a limited production car that make the car what it is. I've owned a '69 Z/28 for 43 years, so of course I am prejudiced!
Hope you find what you are looking for.
You know you are having fun when you are getting 3.4 mpg !!
08-26-2021, 10:34 AM | #10 |
08-26-2021, 10:39 AM | #11 |
I have been thinking about the lighter weight of the Z/28 verses using the stock SS springs. I am thinking I might need lowering springs to maintain the stock SS ride height. Of course the wider Z/28 wheels and 19" instead of 20" will also affect the ride height. 1 inch lowering? What do you think? I will also most likely be removing the front splitter to gain some ground clearance.
08-26-2021, 10:50 AM | #12 | |
08-26-2021, 10:57 AM | #13 |
08-26-2021, 11:05 AM | #14 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
You may be able to accomplish your goal by switching to 18" wheels with taller sidewall and a touring compound. Then when you finally decide to run out at Blackhawk Farms or Auto X at Rockford Speedway you can do a quick tire/wheel swap. Hate to tell ya but even a stock SS suspension (especially with lowering springs!) is going to have a bumpy ride on those N. Illinois roads.
