Old 08-30-2021, 05:07 PM   #1
moloko
moloko's Avatar
Drives: Camaro V6 2011 and 2014 V6
Annoying noise (video)
Hello buddies. My 2014 Camaro started a few months ago with a very annoying noise between the rear left wheel when in motion. I already tried changing the brake pads and rectifying the discs but apparently the noise comes from the differential I think?, can someone help me identify which parts I have to repair to end that annoying noise?
moloko is offline   Reply With Quote
Old 08-31-2021, 11:23 AM   #2
InFiD3ViL
InFiD3ViL's Avatar
Whoa, what the heck? It almost has an electronic noise kind of sound to it.
Bearing or diff maybe? Have you considered getting it on stands and spinning by hand? That may not work without the weight of the car on the suspension though, but it's worth a shot.
Old 08-31-2021, 01:51 PM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Prolly a bad wheel bearing.
More to come.
Black_SS10 is offline   Reply With Quote
Old 08-31-2021, 03:09 PM   #4
gtstorey
That's where I would start and the move to the axels.
Old 08-31-2021, 07:50 PM   #5
moloko
moloko's Avatar
A few days ago with a cousin and his mechanic friend raised that side of the car with the jack and I put the shifter in D and the car made the same sound when it was raised off the ground.
The right side of the car being on the ground, only the left side we jacked up.
Only the back left side makes that sound and it is not the brake.
Old 08-31-2021, 11:47 PM   #6
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
That's a weird noise. I'm guessing a bearing near the differential. I just replace to leaky CV seals on my dif, they never made a sound before failing. I just happened to notice leaking oil.
My car is making a weird noise above 4,000 rpm... Like a old school supercharger. Car runs great. Still makes the noise if I rev in neutral. I'm trying to figure it out with no luck.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 09-01-2021, 08:12 AM   #7
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Definitely a metallic rubbing. I think wheel bearing or diff. Good luck with it.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 09-01-2021, 08:51 AM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I was expecting a video of a wife complaining from the passenger seat.
Old 09-01-2021, 03:03 PM   #9
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Check wheel bearings. Then take axles apart. Preferable drivers side first
Life is short, drive it like you stole it!
Wizard1183 is online now   Reply With Quote
Old 09-02-2021, 10:30 AM   #10
moloko
moloko's Avatar
I am going to tell my cousin who helps me in mechanics to check where I was told. Thanks!
Old 09-15-2021, 06:01 PM   #11
moloko
moloko's Avatar
I forgot to comment that the car when putting in reverse makes a " tuc " noise, we suspect it is the u joint. Sometimes when putting the car from R (reverse) in D it also makes the " tuc "
Maybe it has something to do with the annoying noise shown in the video.
In addition, when moving in reverse the car does not make any noise when in motion.
Old 09-15-2021, 06:11 PM   #12
TheFlyingBananaSS
Wait... what? WTF is a "tuc" noise?
Old 09-15-2021, 07:26 PM   #13
InFiD3ViL
InFiD3ViL's Avatar
Very similar to a Tic, but two vowels lower
Old 09-15-2021, 08:52 PM   #14
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
LOL, that’s quick witted and we’ll played. My hats off to you sir.
HOJO is online now   Reply With Quote
