09-17-2021, 05:45 AM | #1 |
License plate light failure!
Yesterday i changed my license plate light and today i got this message even though everything is working fine, is there any way to reset that ?
09-17-2021, 07:07 AM | #2 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
You've had more damn (weird) issues with that car than I've ever seen. Seems like you either need to leave the car alone or get rid of it and purchase something else.
You don't simply change a license plate bulb, properly, and come up with an error message. |
09-17-2021, 08:00 AM | #3 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
I had one of the LED license plate bulbs I installed fail and didn't see this message, perhaps this only happens when both fail or the wiring harness has a continuity problem (but then you're saying it works fine...). How about disconnecting the battery for 15-20 minutes and perhaps using different bulbs? I sure wouldn't ditch a fine car over this alone
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
09-17-2021, 08:13 AM | #4 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
After I put LED lights in my 2016, I had intermittent failures.
First, the LED license plate bulb. Bulb failed repeatedly. Second, Diode Dynamic side marker light and I had repeated battery drain down (dead). I return the car to stock and the problems went away. Never again ...my 18 and 20 remain stock.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
09-17-2021, 09:04 AM | #5 |
Drives: 2017 2SS, 50th pkg, M6, MRC, NPP Join Date: Jan 2016
as above, I think first question is what did meavt use to replace the original bulb?
09-17-2021, 09:11 AM | #6 | |
About the license plate bulbs I replaced them and this message appeared 1 time and then it went away so its good now. I think that the message came because the bulbs are cheap other than that the car is perfect. |
09-17-2021, 09:12 AM | #7 |
09-17-2021, 09:13 AM | #8 | |
09-17-2021, 09:17 AM | #9 | |
09-17-2021, 10:15 AM | #10 |
Match the wattage to the original bulb. Going too low may cause an error. License plate bulbs are usually low to begin with.
09-17-2021, 11:41 AM | #11 |
09-17-2021, 12:52 PM | #12 |
From the manual. Looks like a 5 W, which is typical:
License Plate W5WLL |
09-17-2021, 03:23 PM | #13 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
FWIW, I have converted the license plate lights to Sylvania LEDs and I don't have any issues.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
09-17-2021, 07:50 PM | #14 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
I just went to the Autozone and got some compatible white LED bulbs. Direct replacement. No fuss and still looking great years later.
