10-24-2021, 10:13 AM | #1 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Race Ramps? Which ones?
Hi, I am looking to get ramps, I started looking at ones around $50 and some how I am now up in the 4 to 5 hundred range.
https://www.raceramps.com/ramps/p/rr-xt-2/ Are these decent? Strong enough? I see they make a HD version of these for $100 more just not sure it is needed. Any other choices? I want to be able to change fluids easily and be able to time bushings if needed. https://www.raceramps.com/c/ramps/ Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
10-24-2021, 11:01 AM | #2 |
It don’t come easy.
I have the 67”, 2 piece ramps. They were around $350, when I bought them 2 years ago. Work great.
10-24-2021, 11:07 AM | #3 |
Drives: 2010 ss Join Date: Oct 2015
i have the two piece 67 as well,best ramps ever.had them for yrs
10-24-2021, 03:40 PM | #4 |
I am okay with spending the money, I just want to be sure I get the best ones.
10-24-2021, 07:04 PM | #5 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I would recommend using their angle of approach calculator.
https://www.raceramps.com/angleofapp...alculator.aspx
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
10-25-2021, 08:10 AM | #6 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
All I wanted was something to help me get the jack under the car. These are the ones I got to help with that since I'm lowered.
https://www.raceramps.com/ramps/p/rr-tj/ allows me to jack it up to the height I want and put jack stands for more secure support. |
10-30-2021, 05:46 AM | #7 |
I have the 67's Coming, hopefully I like them.
10-30-2021, 07:39 AM | #8 |
It don’t come easy.
I think you’ll be satisfied. Did you go with one piece or two?
10-30-2021, 08:46 PM | #9 |
2 piece
10-31-2021, 01:37 PM | #10 |
Drives: 2011 VR SS Vert Join Date: Aug 2015
I had home made ramps until I got lift pads and a low profile jack. Don't have to worry about storing the ramps now.
10-31-2021, 07:22 PM | #11 |
I have a couple Low Profile Jacks and I just added the ZL1 Pads last week as well.
11-05-2021, 04:50 PM | #12 |
The ramps came yesterday, They appear well made I don't have my front splitter on yet and I do think its going to hit, It does push up on the air dam underneath the front bumper, I have a 12x12x1 board cut for each front wheel that i'll have to drive up on. I have not put the car up yet but I will Tomorrow. They are made of a really rough textured foam, Hopefully they last a long time especially for the price.
