11-16-2021, 11:49 AM | #1 |
Drives: 2015 SS Black/Black Join Date: Jun 2016
ATI damper?
Is it necessary to do an ATI damper to install a SC? What's the advantages to using it over the stock? Would you wait until you did the next modes and get over 600whp to do it?
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, and flex fuel
11-16-2021, 02:35 PM | #2 |
Scott S
Drives: 2011 Camaro 2SS Join Date: Sep 2018
Short answer is No. But there is also other questions that need to be answered.
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
11-16-2021, 04:24 PM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
It really depends on the blower. If using stock accessories, not needed. If you're going to use a blower on its own belt, it's absolutely necessary. I'd go with a larger crank pulley over a smaller blower pulley any day.
11-16-2021, 05:17 PM | #4 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Some people choose to replace it because they have to pin the crank pulley and it makes sense while you're in there.
11-17-2021, 06:01 PM | #5 |
While not strictly necessary, some folks would argue that the stock balancer is not designed to handle the additional harmonics created by the addition of the blower. I have done both, but I prefer to run an aftermarket balancer with serious engine mods.
