01-23-2022, 02:11 PM | #1 |
CamaroFans.com
Camaro Fest XI Q&A Thread
Time to kick off the 2022 season as ticket sales are about to get started.
I'll use this thread to answer questions and point folks in the right direction as best I can. |
01-24-2022, 07:33 AM | #2 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
following, Going to try and make it out to this one, never been.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-25-2022, 07:23 AM | #3 |
CamaroFans.com
Then you need to grab a walkie-talkie and join the Houston group on the way there.
01-31-2022, 07:18 PM | #4 |
What's Camaro Fest and the schedule and locations.
Current Vehicles 1963 Split Window Coupe Corvette, 1967 Pontiac LeMans (My first Car), 1972 Chevelle 454SS, 1994 K1500 Silverado, 2021 Camaro ZL1 A10 convertible
01-31-2022, 09:38 PM | #5 |
Love my Satin Steel LT-1!
Drives: 6-Speed LT-1... Join Date: Aug 2016
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels Technology Pkg|NPP|Satin Blk Pkg ZL1 Rock Guards|Red Knee Pad Set PBC LT1 engine built by Debi Lewis |
02-01-2022, 07:59 AM | #6 |
Just saw this, I'd definitely be up for it, so just cruise up the camaro up there. i'd need to stop a ton for gas, i'm current mixed doing 50% 93 and e85. i'm sure i can run up there just on 93 with a light food to the pedal lol. would be fun though. I was thinking i trailer up the car but would almost take the fun out of it.
02-01-2022, 04:53 PM | #7 | |
CamaroFans.com
02-07-2022, 06:22 AM | #8 |
Drives: 1968 Camaro Join Date: Feb 2022
I hope this is the right place to ask this. I plan to make it this year for the first time with my 68. I want to run the strip, AutoX and the track at the NCM. What things do I need to make sure I have covered for tech inspection. I have done a Goodguy AutoX and was fine for that and it is only a 400hp car with 3.42 gears so it isn't like I'll run and ET that requires a roll cage and things like that.
I realize this is a Gen 6 site but I couldn't really find anywhere else to ask this question. I tried emailing the contact email for Camaro Fest but have gotten no answer. Thanks. |
02-07-2022, 01:52 PM | #9 | |
CamaroFans.com
Our tech is not that extensive and if you've done Goodguy you are fine. I saw your e-mail as well but waiting on Joe to answer which I'm sure he will. Anyway... bottom line is you're fine. Only NCM has noise restrictions so if you are running straight pipes it could be an issue at that track. |
02-08-2022, 09:16 AM | #10 |
Thanks for the response. Joe got back to me as well. Looking forward to it.
02-08-2022, 09:27 AM | #11 |
CamaroFans.com
03-02-2022, 12:17 PM | #12 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Booked at the Holiday Inn so see everyone there on Thursday the 7th.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
03-02-2022, 10:20 PM | #13 |
CamaroFans.com
03-02-2022, 11:26 PM | #14 |
I'll be there Wednesday for the early bird meat and greet!
