06-24-2022, 06:32 PM | #1 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Where are the sealed motor (stock cam) guys on LT4 fueling at ,
Hey guys
Finally made the plunge and ordered LT4 hpfp, LT4 injectors and DSX flex fuel sensor. Goal is 600ish WHP on E85 blend with factory reliability like now (Recently moved and have access to E85 now!) Since I bought car 5 years ago I've tried to keep everything as Uncomplicated as possible. Will I NEED an LT4 low side pump ? Logistics of trying to get the parts installed and then tuned before driving the car is probably going to be complicated (Mike from Vengeance Racing is my tuner and Vengeance has stopped installing bolt on parts.....) I'm going to email him tonight to see what he thinks. Thank you guys I haven't done anything to the car in a few years now and things are going to get exciting again I hope!
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
06-24-2022, 07:40 PM | #2 | |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
06-24-2022, 09:18 PM | #3 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Or an aux pump like dsx. I still have LT1 pump w dsx. No JMS either.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
06-24-2022, 09:18 PM | #4 |
Although if i had to do it over, id rather do the in tank. Tapping the tank was not fun.
06-24-2022, 10:17 PM | #5 |
And the DSX is really not a great idea either, if we’re being honest. The tank is super thin and not enough meat there for a proper thread seal. And a tank penetration below the fuel line is usually a no-no. It works, I get it, but there are better and safer options IMO.
06-24-2022, 10:47 PM | #6 |
Drives: 21 Lt1 Join Date: Dec 2016
I made 615whp on 93 with P1X at 9.5 psi with lt4 HPFP, injectors and DSX. Although I agree with Joshinator there are better options. I was able to run e30 blend with same setup
06-24-2022, 10:48 PM | #7 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
06-25-2022, 02:46 AM | #8 | |
If you’re going for big drag/roll race power, the Fore is the way to go. Agree that the install is a big pain, even for a talented shop with fabrication skills. The shop I use does a lot of restomod work and is used to doing custom work. I think I paid them at least a full week of labor to install my Fore system along with a few other odds & ends. Ouch lol! But, once it’s done, you’ve got low side to do virtually anything.
06-25-2022, 08:13 AM | #9 |
Ok very good information
I appreciate it guys Low side is fairly cheap I gotta figure out logistics of getting install and tuning done all at once
16 1SS M6 White
06-25-2022, 08:25 AM | #10 | |
06-25-2022, 09:17 AM | #11 |
Drives: 98 Camaro Join Date: Apr 2022
I was under the impression that you needed the lt4 low side pump OR the jms boost a pump and that would get you to the limit of the Lt1 engine
06-25-2022, 09:23 AM | #12 |
Just looking for a fun consistent street car.
E85 blend seems like the key to beating the heatsoak
16 1SS M6 White
06-25-2022, 09:57 AM | #13 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
On old setup I made 600whp @ 7.5psi on E80 fuel with LT4 injectors, LPE HPFP, LT4 low side and JMS. Cat deletes, regular rotofab, and ported 95mm tb.
We are running a JMS on my brothers ZL1. It made 660/650 on a Mustang dyno that reads 5-6% lower then a DJ. It has +30 injectors, LPE HPFP, Headers, 14psi, E60 fuel. Turning the rail pressure down for the larger injectors and pump took strain off the low side. So imo the LT4 low side pump with a JMS can probably go mid 7xx whp with the right setup. I would suggest factoring any potential future goals before spending money on fueling. The LT4 high side will allow you to run E50-60 where you are now and it's pretty much maxed. If you did +30's and LPE HPFP, you could run full E or turn up the boost and run E60. This is based around a .82 Lambda AFR target.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
06-25-2022, 10:16 AM | #14 |
Once you get past the lt4 fuel stuff the price goes up up up!
