08-27-2022, 02:35 AM | #1 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Electric water pump
Out of curiosity, is anyone running this pump:
https://www.meziere.com/Products/Coo...ace-Model.aspx It looks nice. Might be nice to have at the drag strip since you could run both this pump and the intercooler pump without needing to start the engine.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
08-27-2022, 10:08 AM | #2 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
You seem to be on a roll...bolt that baby up and let us all know. EWP's were always worth some power on older gen 2 LT and LS engines. Not sure why it would be any different. The main difference with gen 5 LT is the direct injection.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
08-27-2022, 10:31 AM | #3 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
I have one on my Gen 2 LT1. I've had good luck with it.
08-28-2022, 08:41 PM | #4 |
I’ll probably give this a try this winter when the car is under the knife (although I feel like it’s under the knife year round at this point lol) for more upgrades. Looks like a really nice piece and I’m liking the thought of running that pump with the car off at the track.
09-04-2022, 05:21 PM | #5 |
Drives: 2016 Camaro Join Date: Oct 2017
I checked into this Meziere pump a while back. With the new LT1 engine there are different belt driven pumps for different vehicles. Hence the inlet and outlet are different based upon the vehicle.
Unfortunately, what Meziere offers is for the racer and the hose locations do not match what we need on the Camaro. You'd need to get the Meziere swivel outlet, and then some special hoses. If you look closely, the LT1 model is the same as the LSx race model. I also suggest the relay kit Meziere makes for their water pumps. SKU WIK346. I have a Meziere water pump on my 2006 GTO and enjoy it. Zero issues. If you do a lot of drag racing the electric water pump can help cool down the engine between rounds.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff. 2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85. |
09-04-2022, 07:25 PM | #6 | |
05-20-2023, 07:24 PM | #7 |
Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Old thread resurrection: Hey Josh did you try this pump?
Roto-Fab w/sound tube delete, Katech ported TB, Pray IM, Velossa, DD side markers, DSX FF, UPR Catch can, Halo brace, My custom vent gauge pod
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
05-20-2023, 08:43 PM | #8 |
I did not try it. After @GTO_Gregory’s post it didn’t sound that fun anymore and I honestly forgot all about it. Someone needs to do it up on a Camaro and document the details to make it work. Maybe you @Trochoidal…?
05-21-2023, 06:51 PM | #9 |
Ah, I see this isn’t plug and play and needs some hose management. I wish I had a use for this setup because I’d be all over it. Let’s just say i can make parts from metal.
05-21-2023, 07:21 PM | #10 |
Make the parts already!
05-22-2023, 05:21 PM | #11 |
Follow-up.
I'm still waiting on my engine, so I'm no further along. I have the GenV Meziere LT1 full electric water pump in my hands, but it will be many months before I get the Meziere LT1 electric pump on the new engine and in the car. For what it's worth, I picked up ONLY a Meziere electric motor for an early LT1 (1970-1972), but the bolt pattern of the Meziere electric motor is different from the early LT1 water pump. If you have a lathe and vertical mill you can make an adapter plate. While the early LT1 spins in the opposite direction of the GenV LT1 this issue can be resolved by reversing the DC power wires. I verified this fix with Meziere. This is possible. Right now there is no direct bolt in electric water pump for a daily driver.
05-04-2024, 11:55 AM | #12 | |
That guy
I was considering one for the '18 6.2 Escalade when mine seized up last night. I guess I'll be installing a mechanical one.
James Montigny
2017 Camaro 2SS A8 - Krypton Green Magnuson 2650, TSP Head/Cam, DSX Low Side, Flex Fuel, LT4 HPFP, 103mm TB, Big Gulp. |
05-04-2024, 02:12 PM | #13 |
I wonder if this situation has changed in the two years that have gone by since I originally started this thread. At nearly $900 you’d think they’d have it sorted out…
05-04-2024, 08:04 PM | #14 | ||
That guy
It replaces the entire casting and moves the pump to the center of the engine. https://gwatneyperformance.com/produ...-kit-preorder/ I assume that you then run your alternator on a short belt. I also found this custom project that fits in the stock casting, but I don't see that it was ever produced in any significant quantity.
James Montigny
