09-04-2022, 01:27 PM | #1 |
Drives: ‘10 1SS RS aqua blue metallic. Join Date: Mar 2020
Cam question
Had this cam recommended. 228/234. 627/627. On 112 + 3. LS-3 with 17/8 headers, hi flow cats, Outlaw cat back, CAI, some suspension mods recently also. Don’t track the car and not a daily driver. Drive it 2-3 times a week. Looking for a bit more power and a nice rumble never hurts. Doubt I ever add SC. Stock gears, car pulls really hard in 1st and 2nd. When hitting 3 rd gear on full pedal it doesn’t have a lot. Maybe that’s normal but hoping a cam helps but maybe folks on here can input. Have a safe Labor Day to all
2010 1SS RS LS 3. Aqua blue metallic.
09-04-2022, 10:26 PM | #2 |
Stock gears? Get some 4.10s
I'd go with a stage 4 cam like the TSP F35
09-05-2022, 01:49 AM | #3 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Depends on whether or not your manual or auto. Cause on that cam if your auto you're at the end of the spectrum for needing a converter. If your looking for something in the lines of those specs, then I would look at a TSP stage 3 or a GPI SS3.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
09-05-2022, 02:02 AM | #4 |
It don’t come easy.
It appears that in his sig, it’s a manual.
09-05-2022, 02:24 AM | #5 |
Yeah it's the details that get you. I didn't even notice that. lol
09-05-2022, 02:51 AM | #6 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
If you're just using the car for some good cruising along with a few good, hard therapeutic pulls I'd say get a cam that has similar specs to the GM crate 525 HP LS3. A duration of 226 in/236 ex, 110 LSA and a 525 lift that won't cause excessive valve spring stress. Do the LS2 timing chain damper and CHE trunion upgrade for reliability. Throw in some 3.91 gears (factory orig in Z/28 and 1LE) and you're ready to go. Oh, almost forgot. A good, reputable tuner to take full advantage of your new components!
09-17-2022, 04:53 PM | #7 | |
Drives: 2012 SS Join Date: Feb 2016
I agree. I have the howards version of the asa cam except mine is on a 113 lsa, with PAC 1218 springs. This cam, while alot of people look down on it, does what I need it to do. Slightly choppy idle ( get compliments everywhere I go) Pulls pretty hard, yet drives like stock.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
09-25-2022, 11:01 AM | #8 |
Thanks all for the input. I’ve been considering a gear change. I just want to make sure I get a compatible combo of gears and cam. I put 4:11 in my first car, 69 Cougar, and that made a massive difference. But I believe the stock gear were in the 2:70 range so it was a big difference. Going from 3:45 to 4:10 or 3:91 won’t be as drastic but definitely noticeable I’ve been told.
09-25-2022, 05:16 PM | #9 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Any big/aggressive cam is gonna want gearing. I did a full N/A ls3 build and went with GM 3.91 gears. It was nasty for what it was. Not an extreme n/a build. But did 530whp. I am now running the same gears boosted.
More to come. |
09-27-2022, 10:09 AM | #10 |
Black SS-10 thanks for the post. I’m really liking the idea of gear change. And if I ever got a wild hair and went with a SC it sounds like I would be good to go with gearing. My car while it only has headers , CAI, pulls good, can’t imagine with gears and cam.
09-27-2022, 03:17 PM | #11 | |
SomeguyK
More to come. |
