10-04-2022, 04:45 AM | #1 |
Drives: Chevrolet Camaro ZL1 Join Date: Aug 2022
Launch Control
Just looking for a little help on the launch control. Just got my 2012 ZL1 manual and decided to try the launch control before i go to the track. Went to a side road, went to setting 4 for street use, matted the throttle, let the rpm's go up and settle back down and then let off the clutch moderately. I tried this about 4 times with the same results, which was a long controlled burnout. It was nothing like I've seen in videos. A quick question.
-Do you keep the throttle to the floor after letting off of the clutch for the remainder of the run? I tried one time slightly letting off the throttle after releasing the clutch, and traction control kicked in and basically stopped me. |
10-04-2022, 05:24 AM | #2 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Release the clutch quickly while holding the throttle slammed to the floor.
10-04-2022, 05:25 AM | #3 |
Happy_Dan
I didn't know the 2012 had launch control.
10-04-2022, 07:20 AM | #4 |
That's weird, because a gm video I watched about it said to release the clutch slightly faster than you would with taking off, and that doing it too quickly could damage the drivetrain. It also made mention of not side stepping it. Thanks for the reply.
10-04-2022, 07:50 AM | #5 |
From the manual....
Launch Control (V8 with Manual Transmission Models Only) A Launch Control feature is available, within Competitive Driving Mode on vehicles with a manual transmission to allow the driver to achieve high levels of vehicle acceleration in a straight line. Launch Control is a form of traction control that manages tire spin while launching the vehicle. This feature is intended for use during closed course race events where consistent zero to sixty and quarter mile times are desirable. Launch Control is only available when the following criteria are met: 1. Competitive Driving Mode is selected. 2. The vehicle is not moving. 3. The steering wheel is pointing straight. 4. The clutch is pressed and the vehicle is in first gear. 5. The accelerator pedal is rapidly applied to wide open throttle. The Launch Control feature will initially limit engine speed as the driver rapidly applies the accelerator pedal to wide open throttle. A smooth, quick release of the clutch, while maintaining the fully pressed accelerator pedal, will manage wheel slip. Complete shifts as described in Manual Transmission on page 8‑30. After the vehicle is launched, the system continues in Competitive Mode. Competitive Driving Mode and Launch Control are systems designed for a closed course race track and not intended for use on public roads. The systems are not intended to compensate for lack of driver experience or familiarity with the race track. |
10-04-2022, 12:31 PM | #6 | |
I did read the manual.. It doesn't seem to be working when doing it like that though. |
10-04-2022, 08:57 PM | #7 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
10-05-2022, 06:55 AM | #8 |
10-05-2022, 07:05 AM | #9 | ||
GPI Sales Consultant
The factory launch control works ok inside of a fairly narrow set of parameters - surface temperature, surface type, tires, modifications (non), etc. Once you start to wander outside of those parameters, it becomes fairly useless fairly quickly. The best thing you can do is learn to launch the car yourself. It will ultimately serve you well to understand what it will take for power, clutch release, etc. If you're looking to get more seriously into drag racing, I recommend learning to use a light preload against the emergency brake, both to improve consistency and to help reduce potential breakage - although the ZL1 is substantially more tolerant of abuse than the SS. I have a tutorial on launch technique for these cars, if it's something you're interested in. It's a little lengthy, but there is a bunch of good information in there for the stick shift guys looking to drag race these cars.
Got a question about a GPI product? Feel free to shoot me a message! |
10-05-2022, 07:25 AM | #10 | ||
Sounds good. Ill check it out. Thanks for the info. |
10-05-2022, 10:06 PM | #11 |
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins Join Date: Jul 2015
I used launch control today for the first time. Worked pretty good. 4.53 0-60 with my 180lb kid riding shotgun.
I think you have to be in PTM 5 |
10-06-2022, 11:07 AM | #12 |
Drives: 2014 RRM ZL1 Join Date: Apr 2014
I have a 2014 M6 coupe and have used the launch control a few times noncompetitively to see what it was like and how it worked. I do not recall what PTM mode I was in, but I followed the manuals instructions almost exactly. The car squatted and launched straight but could feel a little wiggle and it did leave black marks on the road, I mean track, but would not say it was a controlled burnout as there was no smoke from the tires. in my opinion If you're not red lining (assuming hitting shifts) or completely smoking the tires id, think it is working or at least at its limit trying its best to hold traction.
10-10-2022, 04:22 PM | #13 |
10-10-2022, 08:04 PM | #14 |
