10-14-2022, 08:57 AM | #1 |
Camaros Of Northwest Ohio
2023 SS 1LE allocation, finally
I ordered a 2022 1LE back in early April, and changed to a 2023 at the end of April, before I found out 1LEs were moving to FS. A couple of weeks ago, I finally got a 2023 SS 1LE allocation. I currently run a 2016 SS in FS, so I'm hoping to be a bit more competitive to the local fast guys. I will be ordering the APEX ARC-8 19" setup on black Friday, along with Falkens in a 305 / 315 staggered setup. So I have a couple of questions
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
10-14-2022, 11:51 AM | #2 |
PaPa Smurf
The sway bar will make a small amount of difference if any. Drive with the stocker for a while. The 1LE cars and ZL1's have the harness moved from the factory. After the sway bar and wheels/tires mods will put you in a modified class or CAMC.
2022 Rapid Blue SS 1LE
10-14-2022, 12:40 PM | #3 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
My 2020 SS 1LE did not have the harness relocated from the factory. I just relocated it myself recently after 315s appear to have started wearing a hole in the liner. It's easy to check, and if yours turns out to still be in the old location, just relocate it.
Most (maybe all?) top FS drivers nationally run either the BMR or Hotchkiss adjustable front bars. I run a BMR, and the advantage to it is that on its softest setting it's basically the same stiffness as stock. The disadvantage is that the center bushings have not held up well for a lot of folks. I personally inspect mine and have decided to replace just those bushings (they are cheap) once a year even if all looks well. There's a big thread on that somewhere here, and one person came up with a fix. The Hotchkiss bar has the same 1/25" outer diameter but a thicker wall thickness (both bars are hollow). So its softest setting is significantly stiffer than stock. I love the turn-in you get with stock front roll stiffness, but it seems to put power down better with at least one step stiffer front bar. The other obvious "mod" is to get it aligned. Dial in all the camber you can in front and zero toe. In back, toe will be the limiter for camber: dial in all the camber you can while keeping 0-1/16" toe.
Matt Miller
2020 SS 1LE |
10-14-2022, 02:01 PM | #4 | |
It's easy enough to check the location of the harness, and will do so when I get the car. Thanks Bill
10-14-2022, 02:15 PM | #5 | ||
I am familiar with the BMR bars, I just never pulled the trigger. It's good that stock stiffness is the starting point. Thanks Bill
10-14-2022, 02:49 PM | #6 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
I have had no issue with the harness but i also only race on them. i dont drive on the street with them. if you plan on that then i would move it.
as mentioned above. do a few events stock, with falkens, get a feel for it then change it
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
10-14-2022, 03:19 PM | #7 | |
Bill
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) Last edited by wrankin; 10-15-2022 at 01:43 PM. |
10-17-2022, 05:56 PM | #8 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
10-18-2022, 05:12 AM | #9 | |
Bill
