10-20-2022, 03:35 PM | #1 |
DIC Warning
I was driving this morning when all the sudden a warning came on the DIC. The warning said "AC off due to high engine temp", the gauge on the dashboard temp wasn't functioning as well as the 4 pack cluster temp also wasn't functioning. It was a cold morning and I didn't have the air on I had the heater on. I pulled over and opened the hood and there was no wave of super heat. I turned around and went back home. Im assuming a sensor, but I dont know which is the reason for the thread.
10-20-2022, 04:00 PM | #2 |
It don’t come easy.
Check your overflow tank/radiator. Happened to me, when the fluid is low.
10-21-2022, 06:41 AM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Happened to me when the fans stopped working and I was parked doing some work on my laptop. I looked up and shut it off because it was legit hot. The only sensor I know that gives engine temp is the one in the driver's side head in front of the number one exhaust port.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
