11-27-2022, 04:27 PM | #1 |
It finally happened...
Howdy y'all...well, it's been a long minute since I've posted on here. Y'all give some great advice and I've found the answers to most of my questions through y'all. So thank you!! This time, I'm writing with sadness. I believe my L99 finally chewed threw a lifter on start up today. I will post the pics and video for your review. I think I know what happens next, but if anyone has a bunny to pull out of a hat today, I'd appreciate it! Viewer discretion is advised..lol.
11-27-2022, 05:50 PM | #2 |
Drives: '13 Camaro SS '98 Firebird Formula Join Date: Mar 2022
Ouch! Well, that block is probably toast, so if you've gotta go through the effort to pull the motor, may as well do an LS3. And damn, only 4 posts in 8 years? Lol...
11-27-2022, 06:22 PM | #3 |
Tri-County Camaro SWFL
LS3 for sure. Might as well go big too
11-27-2022, 09:24 PM | #4 |
Drives: 2010 2SS/RS Join Date: Dec 2009
416/418 stoker or maybe even a 7.0!!!
Orange Krush II
11-28-2022, 07:47 AM | #5 |
Yes ..I'm not the biggest on posting...lol. Normally, I can find the answers throughout the forum...just this one was bigger haha
11-28-2022, 08:14 AM | #6 |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
That's terrible news... But like everyone above said, now is your chance to build it back better!
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
11-30-2022, 03:07 AM | #7 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Here’s the deal, that block is toast. The question shouldn’t be to go ls3 unless you want to buy a crate motor. You have all kinds of options. go find a gen 4 6.2 block and start with that. If it’s a budget themed build, see if you can reuse the crank and put after market rods and pistons in it. Or look at stroker kits. Then, look at the different head choices. you could put the lighter intake valves on your 823s and reuse them. All kinds of options!
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported LS3 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, 1 Walbro 450lph, 2 525lph return style fuel system, deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
11-30-2022, 05:23 AM | #8 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
How many miles were on it?
BTW I voted LS3.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
12-02-2022, 08:34 AM | #9 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Time for a resleeved 427
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
12-02-2022, 11:06 AM | #10 |
Drives: 13' 1LE Join Date: Apr 2012
Get the cheaper stroker alum block you can get. You dont 'need' an LS3. Could be a resleeved anything.
Good luck. Threat yourself with a 416ci.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
Tags |
l99 cam, l99 engine |
