12-19-2022, 08:57 AM | #1 |
Drives: '23 2SS 1LE - Rapid Blue Join Date: Sep 2021
Driving 1LE in EXTREME cold
Hey Folks,
Since I got my 1LE back in November, my family back home is wanting me to bring it during Christmas to they can see it. I've been reading some things that's making me start to question driving it back to Alabama for the holidays. Since the 1LE has summer only tires, I'm fearful of cracks in the tire or other issues. It's supposed to around 15F degrees ambient when we're leaving Friday night, and lows in the 10s the whole weekend. We have a 2-hour drive Friday night. Staying overnight Friday/Saturday, car will be sitting outside, and driving another hour Christmas morning. Thoughts?
'23 2SS 1LE in Rapid Blue found in transit
1100 Order Placed at Dealership - 10/17/22 Found another in transit - placed deposit and cancelled existing order - 10/26/22 Picked up - 11/5/22 |
12-19-2022, 09:03 AM | #2 |
Drives: 2SS 1LE Join Date: Oct 2011
and you think that's extreme? As long as you have the right tires, it's fine.
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
12-19-2022, 09:13 AM | #3 |
Drives: E92 BMW M3 Join Date: Oct 2012
I would not consider driving in those temps on stock 1LE tires. Regardless of tracking, traction will be non-existent.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
12-19-2022, 09:20 AM | #4 | |
Did some more research and it sounds like Goodyear Eagle F1 SuperCar 3s will possibly have issues in the scenarios I mentioned. Looks like we're taking the Elantra this weekend... Bummer.
12-19-2022, 09:26 AM | #5 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Yes you definitely do not want to run those tires in those temps.
12-19-2022, 09:49 AM | #6 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I didn’t like running the Supercar3 in anything below 60’s due to traction issues. Michelin PS4S are the better option if running in cooler temps and rain.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
12-19-2022, 10:25 AM | #7 |
So, I'm leaving the car here in Atlanta. I live in an apartment and park the car in a parking garage (obviously not heated). Windchill here Saturday morning is supposed to be like -5.
Should I consider going this week to get some winter tires put on? It doesn't get that cold here very often, but I'm fearful these tires sitting idle in the cold may crack. Or do they only crack from flexing while being driven?
12-19-2022, 11:01 AM | #8 |
They’ll crack from just being in the cold. Put it on jackstands and bring them in to your apartment
12-19-2022, 11:02 AM | #9 |
Drives: 2022 2SS 1LE RAPID BLUE Join Date: Dec 2016
do not operate those goodyears under 30 deg no matter what. see this TSB
https://static.nhtsa.gov/odi/tsbs/20...83781-9999.pdf |
12-19-2022, 11:05 AM | #10 |
Drives: 21 ZL1 Join Date: Feb 2022
I drove my 17 1LE through a Chicago winter. It was no big deal. Take it slow and use snow mode. Mine was manual obv. Easy to second gear start and crawl.
12-19-2022, 11:25 AM | #11 | |
12-19-2022, 12:05 PM | #12 |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
As an alternative, you could put performance all season tires on your 1 LE from a nearby discount tire since they do touchless mounting. That's what i did and is peace of mind driving in cold temps without thinking about it.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
12-19-2022, 12:36 PM | #13 |
Its the driving part, flexing, that is the real concern though sitting in the cold is of concern, too.
12-19-2022, 12:58 PM | #14 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
Manual says, not recommended to drive under 40F, says do not drive under 20F. 200 treadwear are soft, they freeze, they crack. Argue away, but swap tires and save the stockers for summer.
