03-17-2023, 09:34 AM | #1 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Scavenge pump warning light for oil return on turbos
I have an IPS twin turbo set up and its a low mount set up. It has a scavenge pump for the oil return from the turbos and what I'd like to do is wire in a safety light in the car on a pressure switch for it. Has anyone here done that? Or know of a kit that would have everything to do it?
I plan on taking the car on some long trips this summer and in the event that the pump would fail I'd like to catch it asap so I don't cause any unwanted damage. I kinda have something planned out but was just looking for thoughts / ideas. What do you guys think is it worth it or am I just being paranoid?
03-19-2023, 08:13 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
If the pump fails, the oil will push past the seals and into the exhaust. There will be a huge plume of smoke and you cannot miss it. It will be a better warning signal than anything else unless you wire up something to punch you in the face or a screeching tone from your speakers.
It happened to me with an AGP kit. I replaced the pump and after any residual oil was burnt out, there was nothing to indicate anything had ever happened. |
03-20-2023, 12:45 AM | #3 | |
Boosted Moderator
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
03-20-2023, 08:29 AM | #4 | |
Good to know. There's approximately 20k miles on this pump, when did yours fail?
03-20-2023, 10:54 AM | #5 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Yup. Pretty obvious, even to any casual observer. I believe if there is a scavenger pump failure, it won't be a progressive one that happens slowly over time. It will be a quick, definitive failure.
I've driven over 45,000 miles with my AGP setup and only had one failure. That was due to to a problem where my bearing in my turbo came apart (other issue I caused) and a piece lodged in my scavenger pump gear, shearing the pin. Just a $0.27 key stock piece fix with a little filing and away I went. Also, added a screen filter pre-scavenger pump.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
03-23-2023, 01:47 AM | #6 |
Boosted Moderator
Which pump are you running…
My build prior to a dry sump system sported a Turbowerx EXA scavenge pump… I blew up a turbo, badly, and ended up getting a couple of bearings in the scavenge pump itself… As part of the clean-up/repair of the car for the next pass, we removed the pump housing cover plate, removed the bearings the escaped from the turbo center section. Put 12 volts worth of electrons in it and it worked good as new… This was with several minutes of run time against locked up impellers… As has been mentioned, losing a scavenge pump most probably won’t hurt the turbos, as they will become oil saturated, hence the billowing fog behind the car…. Dreksnot has a great idea with the prescreen between the turbo and the scavenge pump… It would be easy to install one in a scavenge box if you have that… With twins, often the turbos dump into a common return “box” and from there the scavenge pump does it’s thing… The pump photo below is a stock photo, and not my actual pump, though mine was just like it, though much dirtier…
03-23-2023, 09:26 AM | #7 | |
