03-29-2023, 06:21 AM | #1 |
Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
Installed H&R Springs, better ride
I installed the H&R springs on my SS 1LE on Monday 3/27. It's only been a couple days but the difference in my ride quality is very noticeable. Hitting the same road bumps or potholes I have in the past the car is far less jarring and it feels like the suspension is actually working now. The ride is much more confidence inspiring as if I am on throttle hard and hit a bump in the road the rear end won't jump and lose traction as easily. The H&R springs are a progressive spring rate spring so part of the spring is softer and part is stiffer, that way the soft part can absorb small jarring bumps while still maintaining a stiff ride.
I highly recommend the springs and besides the better ride quality the car also sits great, still looks OEM but better and still plenty of ground clearance on the lip. I will be doing an autocross and trackday in April and if there is any noticeable difference there I will comment on it. |
03-29-2023, 06:58 AM | #2 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Installed yourself? and did you "clock" the suspension bushings?
03-29-2023, 11:46 AM | #3 |
Drives: 22 2SS 1LE Join Date: Mar 2022
Are they lower than factory?
03-29-2023, 12:49 PM | #4 |
Drives: 2SS 1LE Join Date: Oct 2011
With factory bump-stops, all springs are progressive. If your suspension wasn't working before, something was probably wrong with it.
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
03-29-2023, 01:04 PM | #5 |
03-29-2023, 01:05 PM | #6 |
03-29-2023, 01:06 PM | #7 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Throwing drop springs on usually alters the roll centers, effectively softening the wheel rate. Wheel rate is the real world spring rate the tire sees.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
03-29-2023, 01:06 PM | #8 |
03-29-2023, 01:24 PM | #9 |
Drives: 23 2SS 1LE Join Date: Feb 2019
I am interested to see how autocross and track day go. I could see replacing the springs giving you a better quality ride, but I'm curious how it effects performance when you push the car. The magneride is fine tuned to stock suspension so I wonder how it does with the new H&R springs.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
03-29-2023, 01:35 PM | #10 |
This is true there should be a very slight drop in roll center as well as a slight change in the front McPherson strut angle and lower control arm angle and wheel rate is most dependent on the suspension geometry so that will be affected but I would expect that to be negligible compared to the change in spring rate.
03-29-2023, 03:29 PM | #11 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
03-29-2023, 04:20 PM | #12 |
H&R is definitely on the same boat as eibach. I actually think H&R’s engineering puts them at the top of the pecking order for aftermarket springs. Its the only brand I trust for lowering springs.
03-30-2023, 05:32 PM | #13 |
Drives: 2017 Camaro SS 1LE Join Date: May 2020
You didn't believe me huh? Lol jk
Glad you like em I tracked the car with the springs and on stock springs with very minimal difference in lap times. I doubt anyone outside of a pro driver would actually be able to tell if you never told them the springs were changed. |
03-31-2023, 10:59 AM | #14 | |
