04-09-2023, 08:50 AM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Gates green or Gates RPM
The gates green belt I ordered is 1845mm. (72 5/8)in, would I be able to use gates RPM belt that is 1831mm (72 1/8in)? I'm assuming yes, just have to make sure it's not tightened up all the way since these belts from what ive read have no stretch in them.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-09-2023, 09:10 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I'm running the RPM belt on my Whipple and sized it so it is a real pain to install. There is no stretch from the tensioner.
04-09-2023, 09:54 AM | #3 |
Yeah that's what I've been reading.
04-10-2023, 12:37 PM | #4 |
Drives: 2013 ZL1 Join Date: Nov 2018
I've had an RPM on my ZL1 with a 2.4 upper for 20K miles, no issues and no slip.
I hate the green belts, ugly AF
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
04-10-2023, 04:11 PM | #5 |
Apparently the RMP belts are discontinued. So whatever is left out there in circulation, is what ever that's left.
