05-16-2023, 09:08 AM | #1 |
Drives: 700 rwhp 2010 SS Join Date: Sep 2010
Monster triple disc clutch Knocking?
I purchased a 2010 twin turbo Camaro in December and it has a knock down low if you listen close. It sounds like a hollow metal on metal knock, seems like it happens "every revolution" if that makes sense. Like a rock stuck in a tire. At first I thought maybe a rod knock but I put the car on a lift and you can hear it clear as day in the bellhousing area. It does have a monster triple disc clutch and it's made this noise from day one since I bought it. The cars been on the dyno and its been on plenty of pulls in Mexico and zero issues so far. It almost sounds like a rod knock would but it doesn't have the "speed" that a rod knock would have. Could it just be the clutch? I've never had a triple disc but I've head they can be noisy? My tuner never said anything about it while it was on the dyno so I'm not overly concerned just more curious.
05-16-2023, 10:22 AM | #2 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
Likely, if the noise changes when you depress the clutch, might be. Also, when clutch in and moving into and out of gear changes the noise, still might be clutch issue. Otherwise, probably something else.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
05-16-2023, 11:08 AM | #3 | |
When the clutch is depressed I get a little bit of a "rattle" noise. But the knock is still present. I forgot to mention after the car has been driven and all fluids fully warmed up the "knock" sound seems to go away.
05-16-2023, 12:48 PM | #4 |
My Monster Triple sounds like a shaking tin can with marbles in it when I depress the clutch. Very annoying, but it holds the power. The last 2 or 3 have been that way for me (the 1st was quiet). With what you're saying, I'd be leaning away from the clutch being the "knock" issue.
05-16-2023, 01:13 PM | #5 | |
05-16-2023, 02:31 PM | #6 |
Loose flywheel bolt?
05-16-2023, 02:44 PM | #7 |
I was thinking maybe that, but why it would quiet up after its warm doesn't make sense. I just did an oil change and cut the filter open and didnt see anything alarming as far as excessive bearing material or anything like that. I'll just run it till it breaks or doesn't lol
05-16-2023, 05:08 PM | #8 |
Drives: 2013 ZL1 Join Date: Nov 2018
Floater rattling, if it was me I'd call Monster.
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
