06-18-2023, 03:17 PM | #1 |
Drives: 2023 Camaro 2SS 1LE Join Date: Dec 2022
12V Accessory Plug Lid Removal
Hello, I have a 2023 1LE.. does anyone know how to gently removed the spring loaded lid to the 12v accessory "cigarette lighter" located down by the shifter? I wanted to put a gadget cover on without the lid, but I don't want to just rip off the lid.
06-18-2023, 05:41 PM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Sorry if this is a weird question, but you already have a cover, the lid you want to remove. Is it the hinge that is a problem? Are you trying to squeeze in a USB charger that is too tall and the lid doesn't close? If that is the problem, there are several that fit and allow the lid to close fully, e.g. this one that I use (works perfect): https://www.amazon.com/gp/product/B0BLYX8SHZ
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
06-19-2023, 11:24 AM | #3 |
I just want to put something else in there and not have the lid sticking up. Was hoping I could remove it without breaking it.
06-19-2023, 12:08 PM | #4 |
Drives: Chevrolet Camaro SS Join Date: Jun 2023
If that's all you want, I would suggest trying the one that has been mentioned. I just ordered one also as the compact one I have is a little too big.
08-05-2023, 05:44 PM | #5 |
Drives: 2023 chevrolet camaro Join Date: Jan 2023
Did you end up figuring out how to remove it? I know what you want to do. I just want the dual usb charging port available without having the lid open all the time as I will be using it for lighting. I also bought on/off switches for the lights.
08-10-2023, 08:43 AM | #6 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
These are the socket removal instructions, which means the cover is built-into the actual console.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
08-10-2023, 10:07 AM | #7 |
Electrical Engineer
This is what I have now:
https://www.amazon.com/gp/product/B0BLYX8SHZ And I have a 10' USB-C cable that routes around the passenger side console, between the console and rear seat (fits snugly), then routes back up the driver's side for my use. What I had before stuck out too far:
08-10-2023, 01:52 PM | #8 | |
