Old 09-07-2023, 01:19 PM   #1
Thomas F
Drives: 2012 Camaro RS 45th Anniversary
Will From Overkill
Has anybody heard from Will at Overkill? I bought his tune for my Camaro 2 months ago, sent over 12 emails with no response, and haven't received my tuner.
Thomas F is offline   Reply With Quote
Old 09-07-2023, 01:23 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
All I can say is good luck. If/when you get HP Tuners send me a private message and I can help you out in lieu of Will, if needed.
KillboyPowerhead is offline   Reply With Quote
Old 09-09-2023, 10:53 PM   #3
Thomas F
Unfortunately, I went with the AutoCal one thank you though.
