12-08-2023, 11:16 AM | #1 |
Drives: 2024 ZL1 Join Date: Aug 2023
Beadlock rears skinnies on the front pictures?
Thinking about heading the dragstrip "look" direction with my car. Does anyone have any pics they would like to share?
12-08-2023, 12:15 PM | #2 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Sure, here you go:
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
12-08-2023, 07:18 PM | #3 |
Drives: Nickey Super Camaro Join Date: Nov 2008
2017 NicKey ZL1 Camaro
12-09-2023, 09:32 AM | #4 |
Drives: 18 Camaro 2SS Join Date: Jul 2022
Here's a picture of my 2 Camaro's. Both running skinnies up front and beadlocks on the rear
12-11-2023, 03:06 PM | #5 |
My sled...
2019 COPO #32
427 NA 9.38 142MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
12-12-2023, 04:33 AM | #6 |
Drives: '18 ram 1500 Join Date: Dec 2016
Awesome pics guys! It would be great if you could add the wheel brand/size/offset to your posts thanks!!
2023 ZL1 Radiant Red 6 spd, pdr, carbon fiber hood
1100 10/28/22 2000 12/6/22 3400 12/17/22 TPW 1/9/23 delivered 2/7/23 |
12-12-2023, 05:18 AM | #7 |
12-12-2023, 07:17 AM | #8 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
Everyone loves a good drag set up!
12-12-2023, 07:50 AM | #9 |
2019 COPO #32
12-12-2023, 07:55 AM | #10 |
12-12-2023, 09:53 AM | #11 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Don't mean to derail, but how do these setups drive? Highway driving ok? Around town ok? Or are these strictly for the drag strip?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
12-12-2023, 12:43 PM | #12 |
I dont daily mine but out here in the country it drives perfectly fine! I am used to driving a 1970 chevelle around so this is a dream compared to that! The stall in mine makes the mileage go to shit but once its moving its no problem! If you dont mind the noise!
2019 COPO #32
12-12-2023, 02:15 PM | #13 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Or you could save hundreds of dollars and a bunch of weight and just seal your rear drag pack wheels as I have on my last 3 cars, my red car made 850 plus and never spun the tire on wheels, my white car made over 700 and my C7 which dead hooked on ever pass never spun a tire either. Mount the slicks or drag radials dry, air them up and balance the tires, make sure you mark the tire and the valve stem for perfect alignment. Break them back down and use Permatex High Tack Cement, comes in a small can with a brush attached to the lid. Put a nice coat of Permatex on the bead of the wheel and bead of the tire. Let them get tacky which usually takes about 20 minutes, bead them back up to about 35 psi. Let them set for 24 hours and your ready to go drag racing. I got this information from Mickey Thompson Tech and verified by one of the Kent's Hot Rod Garage who sells Race Stars which I used on my red Camaro and C7. I ran the RC Component Bandits on my White Camaro. But you can do what you want, add weight and spend more money. According to MT and KHRG they have plenty of 1000 hp cars using this mounting/sealing process instead of bead locks.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
12-12-2023, 04:17 PM | #14 |
Both of those cars looks really nice Laynlo!!!!
2019 COPO #32
