03-12-2024, 11:57 AM | #1 |
Drives: '12 2SS 6MT Join Date: Mar 2023
Replacement axles for stockish SS power
So my passenger side axle seal (LS3/M6) has a decent leak, leaves a few quarter sized drops on the garage floor every time it's parked. Looking at some other threads I've seen the axle could need replacing as well, and based off the mileage (93k) probably isn't a bad idea. So that brings me to this question: with GM/Acdelco axles being discontinued, what axles should I get? I have no plans of going beyond FBO power levels anytime in the near future, but do plan on lowering it and do a few autocrosses a year. Even still I feel like 1k+hp rated axles would be overkill, given that I don't launch the car hard. Is there an OE replacement type brand available somewhere (maybe at rockauto / auto parts stores??) that isn't just cheaply made garbage from overseas?
Cold Air Inductions intake w/ race scoop, Borla ATAK Catback, EBC Yellows & RBF 600, BMR strut brace, Z28 replicas, Factory Hurst Shifter
03-12-2024, 01:02 PM | #2 | |
Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181 Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links. |
03-12-2024, 07:24 PM | #3 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Not too long ago someone was able to get OEM Z28 axles but they were over $300 each. Z28 and 1LE axles were the best units for the 10 bolt. The outer CV is slightly larger than the regular SS axle.
I'm not familiar with SKP, but it would be nice if someone built an axle that could take 500whp for under 2k.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
03-13-2024, 05:27 PM | #4 | |
Totally agree with Cracka, and can only find Z28 axles for one side and it was pretty pricey
