Old 03-29-2024, 06:45 PM   #1
Ckmerc
Drives: 2013 zl1
Aftermarket Tac needed after mods?
So curious on what the good folks here have done post mods regarding monitoring RPMs given mods move the redline up?
Ie..after cam, headers, porting blower, e85 convert, performance clutch….etc. my mech said redline will now move up higher.. given that…have many of you have aftermarket tacs vs just staying with standard knowing that redline is now starts 1k or 1.5k rpm’s higher?
Ckmerc is offline   Reply With Quote
Old 03-30-2024, 05:10 PM   #2
bsn
Drives: 2013 ZL1
Why change the tach, it will still read fine. If your mechanic is telling you your redline is now 7,200-7,500 rpm you might want to do some math with the pulleys you are running, the engine might live but the blower probably wont.
bsn is offline   Reply With Quote
Old 03-30-2024, 06:24 PM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Good point bsn. I'm right at the edge of blower speed with 2.5 and 9.55. why would you put in a aftermarket tach? Im assuming you are a 6 speed car because you are worried about the tach. wait and see were the dyno says the hp and tq drops off.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 03-31-2024, 06:01 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
No need for an aftermarket tach. With all my mods, yes it moved my power band to the right from where it was, but my stock tach still reads very well up to the 7500 rpm we pulled on the dyno. In driving my shift points are set to 7000, and my redline is set to 7200.. I'm an auto.
Old 03-31-2024, 06:11 PM   #5
Ckmerc
Drives: 2013 zl1
Basically mech expects (based on similar mods he has done with same engine/gen Camaros and vetts) the engine and blower to make power out to 7k before peaking…. Yes factory tac will read fine but with redline being higher…was just wondering if there was an aftermarket option that you could adjust redline on tac based on results of the dyno tune / engine mods.
I saw a couple options at car shows… some looked like crap..some looked more integrated (digital)..
