04-15-2024, 07:20 PM | #1 |
Drives: 2022 Camaro 1ss 1le Join Date: Jan 2022
2022 a10 tuning worth it?
I have a 22 fbo stage 1 cam tuned by gpi. I was thinking about sending my trans module to hptuners to get unlocked and have it tuned. Is it worth the effort and money? How much faster will it be?
04-15-2024, 09:28 PM | #2 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Lot of posts discussing this. TCM tunes are generally worth a reduction of 2 to 3 tenths of a second in the quarter mile.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15 conversion 1059 WHP/944 WTQ, 9.48@150
04-16-2024, 05:33 AM | #3 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Yes
GM Gen V Calibrator
04-20-2024, 09:34 AM | #4 |
Drives: 2022 Camaro ZL1 Join Date: Sep 2023
Very much yes. There is tq management in the TCM you cant turn off/down if you dont unlock it and tune it. You will be capped at a certain level otherwise.
04-21-2024, 12:00 AM | #5 |
Got it. I already know what ima be doing this weekend. My tcm should be the t93 right ?
04-21-2024, 06:21 AM | #6 |
Drives: 6th gen Join Date: Aug 2013
Livernois is able to unlock the t93 with their tuner. Wonder if hpt will be able to do that soon
22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28 dragpack - 11.68@122
16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
04-21-2024, 09:00 AM | #7 | |
https://www.hptuners.com/product/gm-t93-tcm-services/
04-21-2024, 01:53 PM | #8 | |
Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
This screams "WORTH IT" to me
2022 Camaro LT1 A10 - Drag Pack/AxleBack -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock FJB |
04-21-2024, 05:46 PM | #9 | |
04-21-2024, 06:24 PM | #10 |
Much better off with HPT then any of the solid LTx tuners can work their magic. No way Id want to be locked into one shop.
04-21-2024, 06:42 PM | #11 |
I agree. I already have the ecm unlocked with hpt and the tune is finished. I’m not going to their tuner. I’m just wondering if hpt will go this route eventually since it’s proven possible. The tcm tuning is really the last part. I’d rather not fiddle with taking it out and mailing it if I don’t have to.
04-24-2024, 08:29 AM | #12 | |
FBO, LOL! this is a good one that has no meaning because it means something different to everyone on the planet. Not picking on you, Humans tend to follow trends even when they are bad ones. I can unlock TCMs in house, no need to send to HPtuners any more, Your tuner should have the equipment by now. The ECM calibration is a crucial to how the trans works. These are torque based systems, so if the ECM CALIBRATION is off even the slightest, the TCM will not know what to do with the wrong torque reported by the ECM. Stock A-10 Calibration is Spot on when torque reporting is correct. So any gains from trans tuning on a modified car are typically to cover up poor torque reporting, otherwise little to no gains are to be had. Also note you there is no drop in tune that will automatically make your car faster it would be a work in progress and you could potentially go backwards, again depending on ECM Calibration accuracy. Changing Shift points to work better with a larger cam to take advantage of higher RPM Power curve capability are a benefit mostly in a drag racing venue. This subject is a very deep one that most people will not understand so take what I am telling you very seriously. Whether you can gain ET from Transmission tuning is all dependent on ECM CALIBRATION and modification list.
www.jannettyracing.com
04-24-2024, 09:04 AM | #13 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Once you mod the car, the throttle will NOT open all the way at the hit of the throttle in the first couple gears. You will exceed the commanded torque by gear limit in the TCM. It gets worse as you do more mods.
Even a bone stock car will not open the throttle all the way on the launch until it rolls out. You will see a delay where the throttle is only 56-70% open for a second or two before the throttle actually opens all the way. This is a limitation in the TCM. Most of the gains being mentioned are from the ability to launch harder. From a roll you might not see any gains depending on the setup. This has been proven at the track with video.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
04-25-2024, 06:58 AM | #14 | |
Petro-sexual
You are getting around that with MIN SPARK ADVANCE...
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
