05-14-2024, 09:19 PM | #1 |
3P171 USAF Combat Arms
Drives: 2013 SS/RS Join Date: Jul 2021
Anyone running a 390/40-17 M&H tires?
I have found multiple photos of 5th gens running these and asked in the tire forum but I’m hoping I can find someone near Eastern PA that has them on before I order mine to test fit. Thanks.
416ci LS3/Vortech V7/Built 6L80
994.4 RWHP 793.8 RWTQ |
05-15-2024, 08:15 AM | #2 |
GPI Sales Consultant
I'd love to see a photo of a 390 width rear tire on a 5th gen - share 'em up!
Got a question about a GPI product? Feel free to shoot me a message! |
05-15-2024, 08:28 AM | #3 |
Here you go Andrew:
05-15-2024, 10:03 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I run M&H slicks and when called before buying, the guy was very chatty so maybe a call to M&H...
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
05-15-2024, 10:12 AM | #5 |
It’s worth a call. Thank you.
05-15-2024, 10:45 AM | #6 | |
235/55-18 Firestone Indy 500 325/45-17 M&H DOT drag radial Probably going to go with Welds F&R and bead locks on the rear.
05-15-2024, 04:26 PM | #7 |
Boosted Moderator
Based on the screen shot you posted, are you going to call Ted J and see what he has to say about it....
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
05-15-2024, 04:38 PM | #8 | |
235/60-18 (not sure what brand) 315/50-17 Mickey Thompson Street ET R The MT seems to have better reviews than the M&H.
05-15-2024, 07:27 PM | #9 | |
Boosted Moderator
Glad to hear that, especially with reference to the fronts.... Too many people run skinnies and if/when these boats get sideways, you'll certainly want some meat up front....
05-16-2024, 07:13 AM | #10 |
Thanks for the share Blue13 - pretty tough looking on those fat tires. Has to be tight on the inboard side to not be poking more than that.
05-17-2024, 06:24 AM | #11 | |
MT drag radials have a much better reputation at the track than M&H. I can't say I have seen anyone running M&H DRs, you see M&H slicks but not DRs. How do you feel about having a radial up front with bias plys in the back? I've heard from several people that doing that can put you in the guard rail at the top end of the track if things get squirrelly.
05-17-2024, 03:55 PM | #12 | |||
The point is that the two tire types generate extremely different cornering response, and when you give the front axle more response and lateral grip that's a recipe to make yourself a passenger in a hurry. If you're willing to go far enough to run a bias ply rear, do yourself a favor and match it up front. Track clip of mis-matched tires plus coolant down on the track getting the best of me:
