Old 01-29-2010, 07:06 AM   #1
venice17517
venice17517's Avatar
Drives: 2010 Camaro
TBS on Belt Noise
#09-06-01-013A: Accessory Drive Moan/Growl/Groan/Whine Noise When A/C Compressor Cycles (Replace Accessory Drive Belt) - (Jan 13, 2010)
Subject:Accessory Drive Moan/Growl/Groan/Whine Noise When A/C Compressor Cycles (Replace Accessory Drive Belt)
Models:2010 Chevrolet Camaro
With 3.6L Engine (RPO LLT)
Please Refer to GMVIS
Excludes Vehicles Built After August 3, 2009
Attention: This condition is likely to be misdiagnosed as an A/C compressor due to the condition only being noticed during A/C compressor cycling.
This bulletin is being revised to include vehicle build date information. Please discard Corporate Bulletin Number 09-06-01-013 (Section 06 - Engine).
<A href="#ss1-2382089">Condition
Some customers may comment on an accessory drive belt moan, growl, groan or whine noise that may be present when the engine A/C compressor cycles at moderate to high head pressures at engine Idle and throughout the RPM range.
<A href="#ss2-2382089">Correction
Important: VEHICLES BUILT AFTER AUGUST 3, 2009 ALREADY HAVE THE NEW POLYESTER BELT AND SHOULD NOT BE CHANGED.
An improved accessory drive belt, P/N 92242956, has been introduced. This new belt features a polyester cord to reduce the stiffness over the current production Kevlar cord belt. This belt significantly reduces this condition. Vehicles built after August 3, 2009 already have the new polyester belt and should not be changed.
  1. Verify that the vehicle has this condition.
  2. Replace the accessory drive belt with P/N 92242956. Refer to Drive Belt Replacement in SI.
  3. Verify the condition is corrected.
  4. If the condition is still present, refer to Noise Diagnosis - Air Conditioning (A/C) System in SI.
<A href="#ss3-2382089">Parts Information
Part Number
Description
Qty
92242956
1
<A href="#ss4-2382089">Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
venice17517 is offline   Reply With Quote
Old 01-29-2010, 07:51 AM   #2
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
UMMM Technical Bulletin Service???
Part Number
Description
Qty
92242956
1
Labor Operation
Coop 2010 is offline   Reply With Quote
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
GM is gonna kill me!!!! canadian ss 5th Gen Camaro SS LS LT General Discussions 37 08-09-2012 02:44 PM
Safety Belt Audible Reminder System Temper Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 16 11-14-2009 06:23 PM
Seat belt tension BulletSS 5th Gen Camaro SS LS LT General Discussions 4 11-13-2009 11:19 AM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 10:42 PM
