"Detailing Devil Dog"
Drives: 2001 Corvette Coupe Join Date: Jan 2010
From Clay to Wax - A Quick, Step by Step Video Tutorial!
Hey boys and girls! The Junkman is back with another video series that answers those frequently asked questions, "What order am I supposed to use the products to fix my paint issues? What do I use first? What do I use second?"
Well, these 5 videos will finally put an end to those questions for those who are novices to the Adam's line. In these videos, I explain and give a short demo on which products to use, and the order to use them in if you have swirled and scratched up paint. For any novice to the Adam's line of products, I can guarantee that this will eliminate any confusion on what to use and when to use it! One important note. In the videos, you will hear me talk about "perfecting a spot" before moving on to an adjacent spot in the area you are working. What I mean by that is to get rid of all the swirls, haze or scratches in the very first spot that you start working on using Swirl & Haze Remover (SHR), BEFORE moving to an adjacent spot using SHR. Do not do the whole routine in one spot and then move to an adjacent spot and do the entire routine again. Do the entire car with each step of the process. The reason I say to do this is that you must develop an effective technique the first time you start using a polisher to remove damage from your paint. That's why you want to ensure that the first spot that you start on is as perfect as you desire before you apply your technique to the entire car. If your technique is bad or ineffective, you don't want to apply that bad technique to the entire car because you'll end up tired an disappointed with your results. Once you are satisfied with the way your results turn out in the very first spot you start on using SHR, apply that same technique over the entire car. Remember, perfection may very from owner to owner so set a level of perfection that is realistic and to YOUR satisfaction. So, without further delay, grab you some popcorn and kick up your feet. The Junkman is about to break it all down for you. I promise that by the time you're done with these videos, you WILL know which order to use the polishes and waxes. ![]() ] If your paint is in excellent shape with very minor swirls or scratches, you may be able to skip the use of the Swirl & Haze Remover (SHR) and go straight from claying to the Fine Machine Polish (FMP). If your paint does not need to be clayed (which is determined by the baggie test), then you can start with SHR. If your paint does not need claying and only has very, very little paint damage, you may be able to skip both claying and SHR and start with FMP. All this will make much more sense once you watch the videos and see the order that the products are used. Thus, take them in first, and come back to this paragraph after you have finished. It will all become clear to you at that point. For those who want to implement Revive Polish into this routine, it would come right after FMP. I usually use Revive Polish when doing very dark colors to give the paint that last touch of finesse. There are 2 other waxes that you can use in place of Machine Superwax (MSW, which is what I used in these videos). There's the Americana Carnuba Paste Wax and the Buttery Wax. Either can be used in place of MSW. The Americana goes on fast and comes off fast. You don't wait for it to dry or haze. If you do, you will need a chisel to remove it! It does not protect as long as MSW but it does last quite a while depending on how often you wash the car and whether or not the car is garaged or not. Buttery Wax goes on easy and comes off easy. You will allow it to dry before removing it. It does not last as long as the Americana or MSW, however, it is easy to apply and remove. MSW is the longest lasting protection that Adam's has to date as it is more of a sealant. It also has the ability to mask very small imperfections in your paint. One more time on the order! ![]() 1. Clay 2. SHR 3. FMP 4. Revive Polish (if you want - was not used in this video series). 5. One of the three waxes of your choice. Okay boys and girls, let's see those shiny rides! The Junkman
"Marines - Making the other guy die for his country for over 200 years."
"Dude, its dummy-proof!!" lololol Once again, great videos Junkman!
#3 | |
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
Another great series! Thanks JunkMan!
You da Man!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
Thank you sir!
#6 |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
Junkman-
Could you advise what products to use if you are wanting to do this by hand and not use the PC? Cheers K |
#7 | |
If your car is in immaculate shape, even the rules that I posted in the original post still apply. You would skip using whatever product that is not necessary. It's that simple!
#8 |
Dude dude...........do I need to say it??
![]() Thanks Junkman, I feel a little more comfortable sweating and getting popeye arms (ex navy) versus running the PC just yet. ![]() Cheers K |
#9 | |
#10 |
Junkman, do you every use the PC and a polishing pad to remove any of the polish or wax? or, do you just use the towels to remove the polish and the wax?
thanks
#11 |
I always remove any product by hand. You can get into all the cracks and crevices when you do it by hand.
#12 | |
![]() Thanks! Michael J.
#13 | |
![]() Adam will sometimes place his PC on top of a microfiber towel and remove wax that way. I use to hate doing it by hand too. Finally I quit being lazy and started doing it by hand. It's not bad as long as you're not doing a 30 seat limo.
#14 |
DUDE! They're both the same color!
