Old 03-10-2010, 03:14 PM   #1
jputer
jputer's Avatar
Drives: 2016 1LT Garnet Red
Painted the "Shark Fin"
I painted the XM/Onstar antenna to match my car.
Ordered a new antenna from www.gmpartsdirect.com for $44 shipped. Part # 92239705
Here is what you will need:
Mask, sand and clean...
Paint with adhesion promoter...2 light coats, then 1 medium coat.
Then paint with primer, again 2 light coats and 1 medium coat.
Wet sand with 600 grit W/D sandpaper until it is smooth.
Dry, clean and prime it again, 2 light coats and 1 medium coat.
Time for a few color coats...wet sand lightly with 1000 grit W/D and apply several light coats of clear.
On to installation..
Move the seats forward and fold down the back seat. Protect surfaces that need it...
Tools needed: 8 and 10 mm 1/4" scocket and ratchet, panel tool, upholstry tool and a small flat bladed screwdriver.
Remove the bolt cover from both clothes hangers.
Use the 8 mm socket to remove the bolts and pull hard to remove the hanger retainers.
Remove the two headliner retainers with the panel tool very carefully.
Use the upholstry tool to remove the C-pillar covers. They also cover the rear portion of the side curtain airbags and have very good connectors. You can let them both hang by the black plastic strap that is supposed to keep them from becoming projectiles when the side air bags go off.
Carefully lower the headliner, pulling it out of the B-pillar plastic and forward to the middle of the doors.
This is what you will see above the back edge of the lowered headliner.
Remove the 10 mm bolt and 4 prong antenna retainer and disconnect teh two antenna leads.
Remove the black antenna.
Apply some wax while you have a chance.
Remove the 10 mm bolt and 4 pronged retainer from your freshly painted shark fin and feed the antenna leads through the hole.
Go back inside the car and reverse the steps you took to remove the antenna.
Admire your handiwork.
2011 1LT/RS Summit White A6
jputer is offline   Reply With Quote
Old 03-10-2010, 03:24 PM   #2
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
How close does it match???
2010 2-Tone is offline   Reply With Quote
Old 03-10-2010, 03:44 PM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Now resell your original one and the cycle starts again.
Nice post.
Old 03-10-2010, 03:59 PM   #4
jputer
jputer's Avatar
It matches the other painted plastic on the car (bumper covers, mirrors, etc) perfectly. For some reason all of the Summit White painted plastic looks a little "warmer" in color than the painted metal. I think it has to do with the texture of the plastic and how it reflects the light versus the smoothness of the painted metal areas.
Old 03-10-2010, 04:01 PM   #5
jputer
jputer's Avatar
Nice post.
Do you want a ABM one Paul?
Old 03-10-2010, 04:13 PM   #6
tjmac49
Drives: 2010 Camaro SS/RS, IBM, L99
jputer: Nice job!!!
tjmac49 is offline   Reply With Quote
Old 03-10-2010, 04:16 PM   #7
PAUL SS
PAUL SS's Avatar
I kinda do. Was thinking of painting mine on the car. I am not crazy about taking the inside of my car apart though. It is still as stock as the day it was built.
Old 03-10-2010, 05:14 PM   #8
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Great write up
Old 03-10-2010, 08:25 PM   #9
PAUL SS
PAUL SS's Avatar
What prevents water from getting underneath the antenna and into the car? I've been looking at the pictures and can't see how it seals.
Old 03-10-2010, 09:21 PM   #10
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Looks like a Million Bucks!! Great post!!
Old 03-10-2010, 09:28 PM   #11
STL20102SS
STL20102SS's Avatar
Drives: SW 2010 2SS/RS
I will be doing this to mine now. Great write up!
STL20102SS is offline   Reply With Quote
Old 03-10-2010, 09:32 PM   #12
Don O
Camaro and Vettehead
Don O's Avatar
Drives: 2SS/RS IOM L99 69 427/400 Vette
Looks like that black gasket in the 3rd and 4th pictures.
Looks great.
Don O
Nothing sucks more than that moment during an argument when you realize you're wrong.
Don O is offline   Reply With Quote
Old 03-10-2010, 09:39 PM   #13
ron10
Drives: 2010 2SS IOM L99
you did a great job on this thread and also your car.i love what you did,but that looked like a lot of work.i would tear something up.i don't have the patients you have.
Old 03-10-2010, 11:23 PM   #14
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
I also had this done today. I had ordered a new XM antenna last tuesday from Becky at Rogers Chevrolet and recieved it on friday. Monday I made an appoitment at the local dealership "Desert Auto Plaza" to have the antenna installed. I did not want to mess anything up in my car so I decided to pay to have it done. It was a little more then I expected to pay, the flip side is that it was done correctly and if I have any problems they will have to fix them. I am very happy with the results and I will be posting pictures within the next two days. By the way my car is Red Jewel Tint.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
Hyper Black Chrome Painted Wheels 6liter Wheels and Tires Talk Sponsored by The Tire Rack 189 12-18-2010 06:08 AM
Custom Painted Stripes Underway for Bumleb's Rally Yellow 2SS RumbleBeeSS Cosmetics and Lighting Modification Discussions 140 06-20-2010 12:12 AM
New from RPI! 2010 Camaro Pre-Painted Body Color Rear Spoiler! $399.00, painted! RPI Designs Exterior Parts & Accessories 10 03-25-2010 02:42 PM
SLP Black Painted Wheels With Machined Face 20" x 8" / 20" x 9" tbyrne Wheels / Tires 9 01-18-2010 11:41 AM
Painted Black Gauges RobbRock Camaro Photos | Spyshots | Video | Media Gallery 37 10-06-2009 09:21 PM
