Old 04-07-2010, 03:08 PM   #1
Jeffro
Jeffro's Avatar
Drives: 2010 Camaro 2SS 6M
Anybody have aftermarket tunnel brace?
I am wondering if anybody has an aftermarket tunnel brace(the crossmember bracket by the stock h-pipe)??? I just noticed that the stock crossmember bracket is thin and cheap! Are they worth it?? What is the purpose of them?? If theyre worth it whats a good brand to get??
Halltech cold air intake
ARH long tube headers 1 7/8
3" exhaust no cats
Borla S type mufflers
Diablosport tune
Jeffro is offline   Reply With Quote
Old 04-07-2010, 03:27 PM   #2
JM10
Se habla español
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
I have this one from BMR:
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 04-07-2010, 04:39 PM   #3
Jeffro
Jeffro's Avatar
JM
That looks nice but why did you get it? Whats the purpose of them? Do aftermarket braces really work?? Where did you get that brace and how much did you pay?
3" exhaust no cats
Diablosport tune
Old 04-07-2010, 04:40 PM   #4
lee
lee's Avatar
Drives: 2010 2ss/rs
theres a guy here on the forum that made his own and it looked pretty cool
lee is offline   Reply With Quote
Old 04-07-2010, 04:42 PM   #5
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I am using the BMR on my car... as are a couple customers. When you combine it with the Sub-Frame connectors it makes a noticeable difference in chassis stiffness. I recommend it if you plan on adding more HP, or really want to improve rearend traction.
ZZcamaro is offline   Reply With Quote
Old 04-07-2010, 04:49 PM   #6
Jeffro
Jeffro's Avatar
Whats the difference between the BMR subframe connectors and the Hotchkis chassis brace?? The only difference I see is the price and with the Hotchkis brace you dont have to buy the tunnel brace seperately.
3" exhaust no cats
Diablosport tune
Old 04-07-2010, 04:50 PM   #7
Jeffro
Jeffro's Avatar
Is it worth just buying an aftermarket tunnel brace or should I just invest my money in something like the Hotchkis chassis brace?
3" exhaust no cats
Diablosport tune
Old 04-07-2010, 04:54 PM   #8
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
I'd get the Hotchkis
Fishdadddy is offline   Reply With Quote
Old 04-07-2010, 05:35 PM   #9
ZZcamaro
I would go ahead and use the SFCs and the tunnel brace. The brace itself will not make much of a difference, but the two combined, you will feel the difference.
Old 04-07-2010, 07:52 PM   #10
g-townmach
I FARTED
Drives: 2010 2SS/RS
I make a CNC machined tunnel brace. Theres a link in my sig to click for pics and more info.
g-townmach is offline   Reply With Quote
Old 04-07-2010, 08:24 PM   #11
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
+1. I did!!
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 04-14-2010, 09:56 AM   #12
BMR Suspension
Drives: 2016 Camaro 2SS
BMR is the only company making a subframe connector for the 2010 Camaro. The BMR subframe connector connects the front subframe to the driveshaft tunnel to the rear subframe.
The other chassis brace connects to the rear cradle, not the rear subframe. The problem is that the rear cradle assembly has a bushing between the cradle and the body of the car. As that bushing flexes, the chassis brace flexes as well.
At BMR, we feel that the best way to stiffen the chassis is to connect the subframe connector from one solid point (front subframe) to another solid point (rear subframe). Even better if you can connect to a 3rd solid point (driveshaft tunnel). Other companies stiffen the chassis by connecting a solid point to a flexible point.
By the way, the BMR piece is $150-$200 less expensive as well.
BMR Suspension is offline   Reply With Quote
Old 04-14-2010, 10:20 AM   #13
Ivan @ Southwest Speed
Best one out in my opinion.
Still trying to get one but every week or so something "more important" pops up. lmao
Heard nothing but great from his products and he's a C5 guy....why wouldn't you want to give him the business first?!!
Good luck,
Ivan
Old 04-14-2010, 03:00 PM   #14
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you're asking if JUST a aftermarket tunnel brace is worth it, IMO, no. The forces on it are lateral and the stock plate works ok, for what it is. Yes if you take it off, you can flex it easily, but bolt it up and try it again. It doesn't bend at all. The "humps" molded into it give it more rigidity. A full chassis brace is the best way to go and I think you have to go aftermarket tunnel brace or modify the stock one for use with the BMR brace. Both the BMR and Hotchkis have their strengths. I like that the Hotchkis is no lower than the lowest point already on the car. The BMR does drop down a little but it's not massively significant. If your car is lowered or going to be lowered, this could possibly be an issue.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
G1 TUNNEL BRACE BY G-TOWNMACH g-townmach Suspension / Chassis / Brakes 48 03-16-2010 06:56 AM
Spohn Extreme Duty Tunnel Brace Released SpohnPerformance Wheels and Tires Talk Sponsored by The Tire Rack 1 10-18-2009 07:43 PM
Camaro Prototype Tunnel Brace Chris@Extreme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 10-16-2009 09:55 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 30 10-12-2009 08:15 AM
BMR Fabrication Launches New Product - 2010 Camaro Driveshaft Tunnel Brace (DTB004) BMR Suspension Suspension / Chassis / Brakes 0 09-30-2009 02:03 AM
