| Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress. |
Thread Tools |
SoCal Race Team #13
Diarmadhi's Camaro (1SS:RS:LS3:SW/BLK)
Current status -
Cruising, just over 50000 miles of pure joy so far... It is also official now, this is going to be an SSX clone. I have all the information I need. It isn't going to be an exact clone, but a variant of the SSX for the road course/autocross. Stay tuned for more wild mods... Saving money for the mods!!!! Next up is some MAJOR rear end work (body, welding, exhaust, ITS A SECRET!!), and some electronic work... definitely stuff never seen before... Out of warranty so its all good now! Fuel post is updated. Maintenance post here soon. Mods in order below... Stock Specs: Order Information Model Year: 2010 Division: CHEVROLET Distrib. Entity: RET Order Type: TRE - Retail Stock Allocation Group: CAM Model: 1ES37 - Camaro: 1SS Coupe MSRP w/DFC: $33,130.00 Current Event: 6000 - Delivered VIN: 2G1FS1EW5A9211363 Vehicle Specifications PEG: 1SS - 1SS Trim: AFJ - Black Sport Cloth Primary Color: GAZ - Summit White Engine: LS3 - 6.2L V8 Engine (Manual Transmission) Emissions: Transmission: MN6 - Manual 6 Speed Transmission Ordered Options: B34: Carpeted floor mats, front FE9: Federal Emissions SGC: Spare Tire and Wheel Not Desired VLI: LPO, Cargo Mat WRS: RS Exterior Package Pictures: 5/4/2010 ![]() ![]() 5/13/2010 ![]() ![]() ![]() 7/3/2011 (Tie rods and trailing arms) ![]() ![]() 9/17/11 (GM White Interior Trim Kit) ![]() ![]() ![]() ![]() 7/12/12 ![]() ![]() 9/15/12 - Stainless Steel Knurled Thumb Screws and Floating Hood (hood strut and mount delete). ![]() ![]() 4/30/13 - Custom coil pack bracket (aluminium - 1.5lbs weight savings). Carbon fiber replacements planned. ![]() Future Plans (0-5 Years):
Longterm Plans (5+ Years):
Total Mods Cost: $2,325.87
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
SoCal Race Team #13
Reserved
Maintenance Post:
Format Date - Mileage - Service Performed [Parts Used (Part #, Quantity)] Comments ------------------- 5/31/2010 - 1113 - Oil Change, Multi-point Inspection [Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts)] Checked oil level, Washer Fluid level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs. ------------------- 12/18/2010 - 10863 - Oil Change, Multi-point Inspection [Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts)] Checked oil level, Washer Fluid level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs. ------------------- 3/31/2011 - 14862 - Insurance Claim Body Work - Driver side between door and rear wheel (road debris caused body/paint damage) Lifetime warranty on work with Elite Collision Center ------------------- 7/23/2011 - 18992 - Oil Change, Multi-point Inspection [Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts)] Checked oil level, Washer Fluid level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs. -------------------- 10/20/2011 - 22573 - Replacement tires Qty - 2 Nitto Invo 245/45/20 Qty - 2 Nitto Invo 275/40/20 ------------------- 1/28/2012 - 27899 - Warranty Work @ Power Chevrolet Replaced HVAC Blower (was squeeking), ordered new dash pad (cracked @ passenger airbag), ordered new catback exhaust (right muffler baffle spot welds broke), included Inspection. ------------------- 2/4/2012 - 28010 - Oil Change, Differential fluid change, Multi-point Inspection [Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts), Royal Purple MaxGear 75W90 1 Quart] Checked oil level, Differential fluid level, Washer Fluid level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs. ------------------- 2/23/2012 - 28459 - Warranty Work @ Power Chevrolet Replaced dash pad (cracked @ passenger airbag), Replaced catback exhaust (right muffler baffle spot welds broke). ------------------- 7/11/2012 - 38782 - Windshield Wiper Replacement [OEM Replacement Driver Side (92231676, 1), OEM Replacement Passenger Side (92231677, 1)] Replaced Driver and Passenger side windshield wipers. ------------------- 9/9/2012 - 40798 - Oil Change, Multi-point Inspection [Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts)] Checked oil level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs. ------------------- 4/20/13 - 49851 - Oil Change, Clutch/Brake fluid change, Air Filter Recharge, Multi-point Inspection [Mobile 1 Oil Filter (M1113, 1), Mobile 1 Full Synthetic Oil (98HC63, 8 Quarts), Preston Dot 4 Brake fluid] Checked oil level, Brake/Clutch fluid level and cleanliness, power steering fluid level, Coolant level, Air filter, tire pressure. All within specs. Wheel lug nuts torqued to 145 ft/lbs, oil drain plug torqued to 45 ft/lbs. ------------------- 5/11/13 - 50502 - Differential fluid change [Royal Purple MaxGear 75W90 1 Quart] ------------------- 5/??/13 - 50XXX - Replacement tires Qty - 2 Nitto NT05 275/40/20
SoCal Race Team #13
Reserved
Fuel (CSV delinated)
Stats Fill-ups: 154 Miles Driven (at last fill-up): 40101 Total Fuel Cost: $7,299.36 Averages Miles Per Tank: 260.29 Miles Gallons Per Fill-up: 13.62 Gallons Tank MPG: 19.27 MPG Price Per Gallon: $3.51 Price Per Tank: $47.40 Delivered 05/12/2010 - 16 Miles Date,Start Mileage,End Mileage,Total Miles,Gallons,Tank MPG,Average MPG, tank $/gal ,Tank total Cost,Total Gas cost,Octane 05/16/10,16,239,223,14.540,15.34,15.34, $2.970 , $43.18 , $43.18 ,91 05/20/10,239,529,290,15.340,18.90,17.12, $2.930 , $44.95 , $88.13 ,91 05/24/10,529,799,270,15.580,17.33,17.19, $2.950 , $45.96 , $134.09 ,91 05/29/10,799,1069,270,15.660,17.24,17.20, $2.830 , $44.32 , $178.41 ,91 06/04/10,1069,1292,223,14.400,15.49,16.86, $2.770 , $39.89 , $218.30 ,91 06/24/10,1292,1575,283,15.410,18.36,17.11, $2.870 , $44.23 , $262.52 ,91 07/02/10,1575,1864,289,15.010,19.25,17.42, $2.990 , $44.88 , $307.40 ,91 07/06/10,1864,2188,324,15.420,21.01,17.87, $2.999 , $46.24 , $353.65 ,91 07/13/10,2188,2483,295,14.535,20.30,18.14, $2.919 , $42.43 , $396.08 ,91 07/18/10,2483,2754,271,14.235,19.04,18.23, $2.979 , $42.41 , $438.48 ,91 07/21/10,2754,3082,328,15.755,20.82,18.46, $2.899 , $45.67 , $484.16 ,91 07/26/10,3082,3383,301,15.096,19.94,18.59, $2.899 , $43.76 , $527.92 ,91 07/30/10,3383,3587,204,10.502,19.42,18.65, $2.959 , $31.08 , $558.99 ,91 07/30/10,3587,3922,335,15.573,21.51,18.85, $3.359 , $52.31 , $611.30 ,91 08/01/10,3922,4096,174,8.643,20.13,18.94, $3.599 , $31.11 , $642.41 ,91 08/02/10,4096,4418,322,14.432,22.31,19.15, $2.919 , $42.13 , $684.54 ,91 08/06/10,4418,4772,354,16.302,21.72,19.30, $2.899 , $47.26 , $731.80 ,91 08/11/10,4772,5065,293,14.588,20.09,19.34, $2.959 , $43.17 , $774.96 ,91 08/18/10,5065,5381,316,15.827,19.97,19.38, $2.939 , $46.52 , $821.48 ,91 08/25/10,5381,5672,291,14.838,19.61,19.39, $2.839 , $42.13 , $863.60 ,91 08/30/10,5672,5944,272,15.076,18.04,19.32, $2.879 , $43.40 , $907.01 ,91 09/08/10,5944,6241,297,15.795,18.80,19.30, $2.779 , $43.89 , $950.90 ,91 09/15/10,6241,6557,316,16.531,19.12,19.29, $2.819 , $46.60 , $997.50 ,91 09/22/10,6557,6859,302,14.758,20.46,19.34, $2.799 , $41.31 ," $1,038.81 ",91 09/29/10,6859,7139,280,14.445,19.38,19.34, $2.799 , $40.43 ," $1,079.24 ",91 10/04/10,7139,7312,173,8.654,19.99,19.37, $2.799 , $24.22 ," $1,103.46 ",91 10/11/10,7312,7579,267,13.913,19.19,19.36, $2.839 , $39.50 ," $1,142.96 ",91 10/16/10,7579,7868,289,15.281,18.91,19.35, $2.849 , $43.54 ," $1,186.50 ",91 10/22/10,7868,8158,290,15.474,18.74,19.32, $2.899 , $44.86 ," $1,231.36 ",91 10/27/10,8158,8435,277,15.352,18.04,19.28, $2.899 , $44.51 ," $1,275.86 ",91 11/08/10,8435,8711,276,14.581,18.93,19.27, $2.939 , $42.85 ," $1,318.72 ",91 11/14/10,8711,8990,279,14.654,19.04,19.26, $2.879 , $42.19 ," $1,360.91 ",91 11/19/10,8990,9296,306,15.211,20.12,19.29, $2.959 , $45.01 ," $1,405.91 ",91 11/24/10,9296,9537,241,12.223,19.72,19.30, $2.939 , $35.92 ," $1,441.84 ",91 12/01/10,9537,9845,308,16.257,18.95,19.29, $2.899 , $47.13 ," $1,488.97 ",91 12/04/10,9845,10061,216,11.805,18.30,19.26, $2.919 , $34.46 ," $1,523.43 ",91 12/10/10,10061,10341,280,14.128,19.82,19.28, $3.019 , $42.65 ," $1,566.08 ",91 12/14/10,10341,10651,310,15.007,20.66,19.32, $3.059 , $45.91 ," $1,611.98 ",91 12/20/10,10651,10919,268,14.710,18.22,19.29, $3.059 , $45.00 ," $1,656.98 ",91 12/28/10,10919,11202,283,15.435,18.33,19.26, $3.059 , $47.22 ," $1,704.20 ",91 01/03/11,11202,11497,295,15.342,19.23,19.26, $3.069 , $47.08 ," $1,751.28 ",91 01/11/11,11497,11774,277,15.139,18.30,19.24, $3.079 , $46.61 ," $1,797.90 ",91 01/18/11,11774,12050,276,14.804,18.64,19.23, $3.089 , $45.73 ," $1,843.63 ",91 01/25/11,12050,12324,274,15.121,18.12,19.20, $3.199 , $48.37 ," $1,892.00 ",91 02/03/11,12324,12606,282,16.204,17.40,19.16, $3.259 , $52.81 ," $1,944.81 ",91 02/09/11,12606,12887,281,15.232,18.45,19.15, $3.359 , $51.16 ," $1,995.97 ",91 02/16/11,12887,13152,265,14.750,17.97,19.12, $3.459 , $51.02 ," $2,046.99 ",91 02/23/11,13152,13415,263,14.820,17.75,19.09, $3.399 , $50.37 ," $2,097.36 ",91 03/01/11,13415,13697,282,14.762,19.10,19.09, $3.559 , $52.54 ," $2,149.90 ",91 03/06/11,13697,13986,289,14.662,19.71,19.10, $3.599 , $52.77 ," $2,202.67 ",91 03/11/11,13986,14280,294,15.095,19.48,19.11, $3.699 , $55.84 ," $2,258.51 ",91 03/21/11,14280,14594,314,15.629,20.09,19.13, $3.659 , $57.19 ," $2,315.69 ",91 03/31/11,14594,14881,287,14.835,19.35,19.13, $3.799 , $56.36 ," $2,372.05 ",91 04/13/11,14881,15104,223,12.726,17.52,19.10, $3.859 , $49.11 ," $2,421.16 ",91 04/15/11,15104,15151,47,5.343,8.80,18.92, $4.049 , $21.63 ," $2,442.80 ",91 04/17/11,15151,15426,275,15.861,17.34,18.89, $3.849 , $61.05 ," $2,503.84 ",91 04/24/11,15426,15677,251,13.480,18.62,18.88, $3.859 , $52.02 ," $2,555.86 ",91 04/29/11,15677,15969,292,15.157,19.27,18.89, $3.919 , $59.40 ," $2,615.26 ",91 05/06/11,15969,16246,277,15.256,18.16,18.88, $3.919 , $59.79 ," $2,675.05 ",91 05/13/11,16246,16529,283,15.862,17.84,18.86, $3.959 , $62.80 ," $2,737.85 ",91 05/20/11,16529,16819,290,15.325,18.92,18.86, $3.919 , $60.06 ," $2,797.91 ",91 05/28/11,16819,17099,280,14.872,18.83,18.86, $3.859 , $57.39 ," $2,855.30 ",91 06/13/11,17099,17378,279,15.455,18.05,18.85, $3.779 , $58.40 ," $2,913.70 ",91 06/21/11,17378,17656,278,15.511,17.92,18.83, $3.659 , $56.75 ," $2,970.46 ",91 06/30/11,17656,17942,286,15.283,18.71,18.83, $3.539 , $54.09 ," $3,024.55 ",91 07/07/11,17942,18228,286,15.994,17.88,18.82, $3.459 , $55.32 ," $3,079.87 ",91 07/13/11,18228,18523,295,15.395,19.16,18.82, $3.459 , $53.25 ," $3,133.12 ",91 07/23/11,18523,18816,293,15.593,18.79,18.82, $3.479 , $54.25 ," $3,187.37 ",91 07/28/11,18816,19090,274,14.600,18.77,18.82, $3.459 , $50.50 ," $3,237.87 ",91 08/02/11,19090,19231,141,8.430,16.73,18.79, $3.479 , $29.33 ," $3,267.20 ",91 08/02/11,19231,19435,204,8.538,23.89,18.86, $3.699 , $31.58 ," $3,298.78 ",91 08/04/11,19435,19680,245,10.802,22.68,18.92, $3.999 , $43.20 ," $3,341.98 ",91 08/04/11,19680,19836,156,6.066,25.72,19.01, $3.699 , $22.44 ," $3,364.41 ",91 08/08/11,19836,20167,331,16.110,20.55,19.03, $3.459 , $55.72 ," $3,420.14 ",91 08/15/11,20167,20420,253,14.831,17.06,19.00, $3.499 , $51.89 ," $3,472.03 ",91 08/22/11,20420,20671,251,14.879,16.87,18.98, $3.399 , $50.57 ," $3,522.61 ",91 08/30/11,20671,20925,254,14.984,16.95,18.95, $3.419 , $51.23 ," $3,573.84 ",91 09/08/11,20925,21195,270,15.319,17.63,18.93, $3.599 , $55.13 ," $3,628.97 ",91 09/15/11,21195,21456,261,14.797,17.64,18.92, $3.579 , $52.96 ," $3,681.93 ",91 09/24/11,21456,21738,282,15.268,18.47,18.91, $3.539 , $54.03 ," $3,735.96 ",91 10/02/11,21738,21973,235,12.915,18.20,18.90, $3.539 , $45.71 ," $3,781.67 ",91 10/09/11,21973,22257,284,15.266,18.60,18.90, $3.519 , $53.72 ," $3,835.39 ",91 10/18/11,22257,22534,277,15.258,18.15,18.89, $3.519 , $53.69 ," $3,889.08 ",91 10/25/11,22534,22786,252,14.586,17.28,18.87, $3.429 , $50.02 ," $3,939.10 ",91 10/30/11,22786,23030,244,14.608,16.70,18.84, $3.559 , $51.99 ," $3,991.09 ",91 10/31/11,23030,23084,54,14.720,3.67,18.67, $3.559 , $52.39 ," $4,043.48 ",91 11/06/11,23084,23332,248,14.262,17.39,18.65, $3.369 , $48.05 ," $4,091.52 ",91 11/12/11,23332,23565,233,13.698,17.01,18.63, $3.559 , $48.75 ," $4,140.28 ",91 11/15/11,23565,23848,283,13.493,20.97,18.66, $3.519 , $47.48 ," $4,187.76 ",91 11/18/11,23848,23965,117,7.127,16.42,18.64, $3.519 , $25.08 ," $4,212.84 ",91 11/18/11,23965,24173,208,9.648,21.56,18.67, $3.599 , $34.72 ," $4,247.56 ",91 11/20/11,24173,24383,210,10.033,20.93,18.69, $4.039 , $40.52 ," $4,288.08 ",91 11/20/11,24383,24528,145,6.223,23.30,18.74, $3.599 , $22.40 ," $4,310.48 ",91 11/23/11,24528,24825,297,15.523,19.13,18.75, $3.379 , $52.45 ," $4,362.93 ",91 12/01/11,24825,25116,291,15.945,18.25,18.74, $3.339 , $53.24 ," $4,416.17 ",91 12/09/11,25116,25380,264,15.165,17.41,18.73, $3.349 , $50.79 ," $4,466.96 ",91 12/15/11,25380,25663,283,15.427,18.34,18.72, $3.349 , $51.67 ," $4,518.63 ",91 12/22/11,25663,25931,268,15.639,17.14,18.71, $3.379 , $52.84 ," $4,571.47 ",91 12/30/11,25931,26211,280,15.448,18.13,18.70, $3.459 , $53.43 ," $4,624.90 ",91 01/06/12,26211,26479,268,14.351,18.67,18.70, $3.499 , $50.21 ," $4,675.12 ",91 01/15/12,26479,26734,255,15.584,16.36,18.68, $3.559 , $55.46 ," $4,730.58 ",91 01/24/12,26734,27000,266,14.985,17.75,18.67, $3.559 , $53.33 ," $4,783.91 ",91 01/27/12,27000,27105,105,6.500,16.15,18.64, $3.699 , $24.04 ," $4,807.96 ",91 01/27/12,27105,27388,283,13.109,21.59,18.67, $3.759 , $49.28 ," $4,857.23 ",91 01/29/12,27388,27563,175,9.910,17.66,18.66, $3.689 , $36.56 ," $4,893.79 ",91 01/31/12,27563,27881,318,14.875,21.38,18.69, $3.639 , $54.13 ," $4,947.92 ",91 02/08/12,27881,28117,236,13.873,17.01,18.67, $3.709 , $51.45 ," $4,999.38 ",91 02/21/12,28117,28371,254,15.997,15.88,18.65, $3.829 , $61.25 ," $5,060.63 ",91 02/28/12,28371,28603,232,13.945,16.64,18.63, $4.059 , $56.60 ," $5,117.23 ",91 03/06/12,28603,28871,268,16.102,16.64,18.61, $4.159 , $66.97 ," $5,184.20 ",91 03/12/12,28871,29175,304,15.912,19.11,18.62, $4.119 , $65.54 ," $5,249.74 ",91 03/19/12,29175,29464,289,15.399,18.77,18.62, $4.209 , $64.81 ," $5,314.56 ",91 03/27/12,29464,29699,235,14.181,16.57,18.60, $4.249 , $60.26 ," $5,374.81 ",91 04/03/12,29699,29953,254,15.152,16.76,18.58, $4.139 , $62.71 ," $5,437.53 ",91 04/09/12,29953,30229,276,15.093,18.29,18.58, $4.089 , $61.72 ," $5,499.24 ",91 04/13/12,30229,30397,168,9.521,17.65,18.57, $4.139 , $39.41 ," $5,538.65 ",91 04/15/12,30397,30644,247,11.910,20.74,18.59, $4.259 , $50.72 ," $5,589.37 ",91 04/18/12,30644,30978,334,16.490,20.25,18.60, $4.049 , $66.77 ," $5,656.14 ",91 04/19/12,30978,31268,290,13.471,21.53,18.63, $4.399 , $59.26 ," $5,715.40 ",91 04/20/12,31268,31367,99,4.123,24.01,18.67, $4.189 , $17.27 ," $5,732.67 ",91 04/20/12,31367,31548,181,9.039,20.02,18.69, $4.199 , $37.95 ," $5,770.63 ",91 04/20/12,31548,31803,255,11.026,23.13,18.72, $3.989 , $43.98 ," $5,814.61 ",91 04/24/12,31803,32055,252,11.210,22.48,18.75, $3.999 , $44.83 ," $5,859.44 ",91 04/24/12,32055,32326,271,11.895,22.78,18.78, $4.159 , $49.47 ," $5,908.91 ",91 04/24/12,32326,32558,232,10.025,23.14,18.82, $4.099 , $41.09 ," $5,950.00 ",91 04/24/12,32558,32694,136,6.675,20.37,18.83, $3.999 , $26.69 ," $5,976.69 ",91 04/29/12,32694,33038,344,14.945,23.02,18.86, $4.099 , $61.26 ," $6,037.95 ",91 05/09/12,33038,33331,293,14.725,19.90,18.87, $4.039 , $59.47 ," $6,097.43 ",91 05/16/12,33331,33597,266,14.355,18.53,18.87, $4.059 , $58.27 ," $6,155.70 ",91 05/23/12,33597,33860,263,13.883,18.94,18.87, $3.959 , $54.96 ," $6,210.66 ",91 06/04/12,33860,34142,282,14.876,18.96,18.87, $3.899 , $58.00 ," $6,268.66 ",91 06/09/12,34142,34441,299,15.292,19.55,18.88, $3.839 , $58.71 ," $6,327.37 ",91 06/15/12,34441,34718,277,15.550,17.81,18.87, $3.759 , $58.45 ," $6,385.82 ",91 06/23/12,34718,35008,290,15.993,18.13,18.86, $3.739 , $59.80 ," $6,445.62 ",91 06/29/12,35008,35293,285,14.709,19.38,18.87, $3.639 , $53.53 ," $6,499.14 ",91 07/07/12,35293,35587,294,15.488,18.98,18.87, $3.599 , $55.74 ," $6,554.88 ",91 07/13/12,35587,35867,280,14.920,18.77,18.87, $3.439 , $51.31 ," $6,606.19 ",91 07/21/12,35867,36159,292,15.346,19.03,18.87, $3.489 , $53.54 ," $6,659.74 ",91 07/26/12,36159,36437,278,14.327,19.40,18.87, $3.419 , $48.98 ," $6,708.72 ",91 07/30/12,36437,36612,175,8.777,19.94,18.88, $3.219 , $28.25 ," $6,736.97 ",91 07/30/12,36612,36810,198,8.362,23.68,18.91, $3.399 , $28.42 ," $6,765.39 ",91 07/30/12,36810,37139,329,13.129,25.06,18.96, $3.659 , $48.04 ," $6,813.43 ",91 07/31/12,37139,37408,269,11.543,23.30,18.99, $3.799 , $43.85 ," $6,857.29 ",89 07/31/12,37408,37538,130,5.131,25.34,19.03, $3.659 , $18.77 ," $6,876.06 ",89 08/01/12,37538,37795,257,11.327,22.69,19.06, $3.559 , $40.31 ," $6,916.37 ",90 08/01/12,37795,37925,130,5.880,22.11,19.08, $3.799 , $22.34 ," $6,938.71 ",93 08/01/12,37925,38239,314,12.813,24.51,19.11, $4.159 , $53.29 ," $6,992.00 ",93 08/05/12,38239,38427,188,11.647,16.14,19.09, $4.119 , $47.97 ," $7,039.97 ",93 08/05/12,38427,38736,309,12.998,23.77,19.13, $3.599 , $46.78 ," $7,086.75 ",90 08/05/12,38736,38910,174,7.332,23.73,19.16, $3.859 , $28.29 ," $7,115.05 ",90 08/06/12,38910,39105,195,8.603,22.67,19.18, $3.999 , $34.40 ," $7,149.45 ",90 08/06/12,39105,39388,283,11.865,23.85,19.21, $3.699 , $43.89 ," $7,193.34 ",91 08/06/12,39388,39724,336,13.852,24.26,19.24, $3.509 , $48.61 ," $7,241.95 ",91 08/09/12,39724,40101,377,16.131,23.37,19.27, $3.559 , $57.41 ," $7,299.36 ",91 Misc
![]() ![]() ![]() ![]() Drives: 2013 300C HEMI, 2012 Ram 4X4 HEMI Join Date: May 2009
Congrats and cloth is the only way to go for an Arizona car. Good choice
Ordered 2014 1SS 1LE NPP Recaros Backup Cam Sunroof AGM:
Status 1100: June 7 Status 2500: June 11 Status 3000: June 12 TPW July 15 |
![]() Drives: Cyber Gray 2SS -RS Join Date: Mar 2010
Pics, please...
#6 |
SoCal Race Team #13
As requested! Cant wait to get her!
Thanks for he photos Scott!
#7 |
E.B.A.H.
Drives: you wild... Join Date: Mar 2007
Congrats D!!! It's been a long time in waiting. You're finally getting it done. I can't wait to see it in October.
#8 |
SoCal Race Team #13
Updated
- Locking Chrome Fuel Door - Security Lug Nuts - Fuel Tracking Format
#9 |
SoCal Race Team #13
Hit 1k miles Friday May 28th on the home from work.
Stopped by checker to pickup the stuff for the first oil change. 9 quarts Mobile 1 Full Synthetic 5W30 (Part # 98HC63) 1 Mobile 1 oil Filter (Part # M1113) change to happen today or tomorrow!
#10 |
1000??? You are out CRUISING!!!!
#11 |
SoCal Race Team #13
Having a great time with the car... and a 40 mile round trip commute
![]() Yea I need to back off the mileage a bit. will happen after my vacation next week (2 weeks with no Camaro!).
#12 |
congrats
#13 |
Tampa Gulf Coast Family
CONGRATS!
#14 |
SoCal Race Team #13
If you want to see this pretty much stock, but rare combination, Camaro...
I will be @ the Duel in the Desert the weekend of October 22nd AND C5F2 in April! PS. - My garage / tools / air compressor will be available for those who want to wrench at either event. Just gotta let me know ahead of time and we will work something out!
#15 |
SoCal Race Team #13
Hit 10800 miles and the OLM is finally getting under 15%. Time for an Oil change!
Still leery about going 9000 miles between changes.. but thats what the owners manual says!
#16 |
SoCal Race Team #13
A day after the installation of the Vararam Intake (early model), I wasn't happy with the way the top end of the radiator floated about, and the mounts with long bolts didn't look appealing to me...
SOOOOOO I fabricated up some real brackets made of 3mm steel plate! Pictures to come once the battery on my camera is charged.
#17 |
SoCal Race Team #13
Pictures of the new bracket and one with it installed (minus factory bolt).
#18 |
SoCal Race Team #13
Update with another TRUE custom mod.
Still some detail work to be a true end result, but good enough for test fitting and photos.
#19 |
John
Drives: 2010 2LT/RS Summit White Join Date: Dec 2009
any tips on the bowtie mod? did you get a bowtie delete plate and then mold the bowtie to it?
#20 |
SoCal Race Team #13
Yes sir,
the gold part is actually glued to a backing that is part of the chrome surround. Picture 1 ![]() 1.a - mask off what you want to keep chrome (or just to protect the surface prior to paint) ![]() 1.b - pop out the gold part ![]() 2. dremel out the backing (VERY CAREFULLY) ![]() 3. use a bowtie delete plate (ends trimmed to fit inside the chrome surround) ![]() 4. clamp the delete inside and expoxy (jbweld) it in. ![]() 5. paint the exposed plastic with a primer and color/black coat. ![]() And the inspiration for this...
#21 |
John
GREAT WRITE UP! thanks!
I saw the SSX bowtie and was curious how they did it
#22 |
On a list for a 2014 Z28
![]() Drives: 2010 Camaro 2SS M6 Join Date: Oct 2008
I like your mod list, and what you did with the bowtie mod.
#23 |
SoCal Race Team #13
Thanks ofer! I need to buy you a round for the intake and have you take a look at my revised vararam brackets. I hope I can get them powder coated prior to next week!
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: v6 rs inferno orange/inferno orange Join Date: Mar 2010
Liked the Bowtie mod.
#25 |
SoCal Race Team #13
Updated the vararam brackets as mine an offers were letting loose under stress.
| Thread Tools | |
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 12:25 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
| Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 05:33 PM |
