06-24-2010, 04:09 PM | #1 |
Drives: 2010 2SS CGM LS3 Join Date: Jan 2010
Three Tier Oil Change
I just did the motor, M6, and rear diff. Mobile 1 in the crankcase, RP in the rest. It took about an hour and a half. Thanks to the members who recommended the 4' section of clear tubing to fill the tranny, it worked flawlessly.
06-24-2010, 04:22 PM | #2 |
I'm planning on doing the same here once I hit 1500 miles. What diameter tubing did you use?
06-24-2010, 05:23 PM | #3 |
Similar Threads | ||||
DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 06:11 PM |
Oil Capacity LS3 | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 77 | 04-21-2014 10:19 PM |
best synthetic oil to use | hollywoodjose | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 130 | 01-26-2014 08:51 AM |
3,000 Miles - No "Metal Shavings" - Anyone Else? | FNKNSTN | 5th Gen Camaro SS LS LT General Discussions | 48 | 10-05-2009 11:46 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
