Old thread, I know but is anyone having problems with the AGP kit at all? I went to tune the car last night and the FP was set at 43.5 like instructions say to do. While tuning it dropped in the 20s at idle. bumped it up again still had problems with it dropping. Tuner took vacuum line off the FPR and tried to tune it static and bumped it up to 58 psi a short while later it was low 50s. Tuner also said every time HP tuners would say to add 2 to 4 percent to the top of every pull. he said has to be a problem. and we stopped. Tuner is Justin White which I am sure a lot know that he is a top tuner in the LS world so I feel confident he knows what he's talking about and not a tuner issue.
1. How many pumps are you running? 2. Are you still utilizing the FPCM or do you have it converted to a return-style fuel system? 3. If you have two or more pumps, have you tried the other pump(s) to see if the condition still persists? |
Question as well 1. Do you have them staged ? 2. If not then how did you set it up if you run all pumps 3. If so then did you have a pressure switch as to when you run the pump based off boost and how much boost you have it set to trigger. |
Old thread but I’m hoping one of the experts has a quick answer :)
What under hood fuse should I use for the Hobbs switch key on/cranking power? I’m currently using fuse 11 (cooling fan relay) for the oil return pump. I tested the fuel system using this fuse just to make sure it powered up, it did, got pressure and no leaks. AGP recommenced using a different circuit as to not mess with the oil pump timer. Suggestions please? |
The above recommendation is only for using a relay, NOT powering the pump directly via the Hobbs switch. -Scott |
It's just turning on the relays (very low power) so any switched acc wire will work. You can use the same wire as your scavenge pump if you tap into it between the fuse and diode. Tapping after the diode will throw things way off.
Awesome, thank you both!
