Old 09-21-2016, 10:11 PM   #1
Ls1408cp
Drives: 14 1le turbo
Who has a AGP fuel system?
Who has agp fuel system and do you like it? I plan on switching to e85 and pushing my car a little harder. Anyone have their flex fuel sensor or fuel rails?
I plan on going to about 16psi on a Huron speed turbo kit. Thanks
Ls1408cp is offline   Reply With Quote
Old 09-22-2016, 03:21 PM   #2
Ls1408cp
Ordered one today. I'll post pics when it's on.
2014 1LE 2SS/RS
Huron Speed turbo kit
Old 09-22-2016, 03:49 PM   #3
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
It's just a Fore kit, with better electrical. Can't beat the pricing. It will be my next purchase.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 09-23-2016, 07:15 AM   #4
Unreal
Drives: 2006 Z06
Like SS said, fore pumps/hat/rails and they source their own lines/electrical to offer the customer savings with same quality.
Nick
Corvette Z06 -1200ish rwhp
Old 01-21-2017, 08:52 PM   #5
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Sorry to bump an old thread, but after almost getting hosed here by a member on a dual pump (thank you paypal for coming through) I learned my lesson and want to buy from a legit vendor. Does the kit come with install instructions and can the install be done in a garage with regular tools?
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 01-21-2017, 09:01 PM   #6
Glushenij
Glushenij's Avatar
Drives: 2014 Camaro 2SS 1LE
I got triple,flex sensor and rails and 1400cc! Great quality and price
AGP TT 807whp 811wtq 13.46psi E85+methanol
Glushenij is offline   Reply With Quote
Old 01-21-2017, 11:19 PM   #7
1KillerSS
1KillerSS's Avatar
Yes it can, at least from the information I've seen.
Build thread
Old 01-21-2017, 11:51 PM   #8
Glushenij
Glushenij's Avatar
Yes u can install in garage-it's what I did! Instruction bare minimum no pic , but it's not hard if u know basic
Old 01-22-2017, 09:26 AM   #9
THUMOS
THUMOS's Avatar
Drives: 2013 Black Camaro 2SS
I installed the dual pump AGP system with flex fuel sensor and 1400cc injectors on my own at home. I'm "shade-tree" at best. Biggest job I had done before that was headers and intake. I cut the trap door for the fuel pump and that made it easier. It was a bigger job than headers, but not as big a job as the AGP TT kit I since installed. The instructions are fairly clear but minimalist. Kevin was good about responding to emails with answers to several questions, though. And this forum is very helpful too. Read the instructions. Visualize. Gather your stuff. Devote some time (and then double that if you are like me LOL). Totally doable for the average guy with tools.
2013 2SS 706rwhp/681tq AGP TT with S256sx turbos, Dual Fore fuel pumps, 1400cc injectors, Flex Fuel on e85, Mcleod RXT Dual Disc clutch, GFB GeForce III, 3" MBRP Exhaust, MGW Short Shifter. Alpine H700, JBL MS-a5001's, MS-a1004's, Faital Pro horn drivers w/Eric Stevens horn bodies, Faital Pro 8's, Acoustic Elegance 15's. Rohana RF 1 Forged wheels.
THUMOS is offline   Reply With Quote
Old 01-23-2017, 09:49 AM   #10
760bowtie
760bowtie's Avatar
Thanks for the replies. I currently have the DSX flex fuel sensor installed, along with a zl1 pump and ADM FPCM. Would the flex fuel sensor and ADM FPCM still work with this kit or do I have to swap back to the oem FPCM? We drop the tank to install the zl1 pump, does it not have to be dropped to install this kit?
Old 01-23-2017, 10:55 AM   #11
THUMOS
THUMOS's Avatar
Don't know on compatibility questions. As for dropping the tank, I just cut the trap door under the rear seat and install was very easy.
Old 01-23-2017, 11:22 AM   #12
Glushenij
Glushenij's Avatar
FPCM don't need as it's don't control your pressure- my last pic show fore fpr ! First pic show fuel tank assembly ( my triple-3 pumps,twin -2 pumps)! So u need pull your zl1 out( like me) and install this one( follow instructions and cut wires! On flex sensor with AGP kit it's come with everything to connect all together ( flex connect in fpr on bottom and require special fitting for AN lines( one side)and another side to stock feed( now it's will be use as return )I think your DSX connect between stock lines!
Old 01-23-2017, 01:48 PM   #13
Unreal
Drives: 2006 Z06
DSX sensor would work just fine. Can remove/sell or do whattever with FPCM since this uses its own system to control pumps.
Nick
Old 01-23-2017, 10:34 PM   #14
silkrckt
silkrckt's Avatar
Drives: 2017 Garnet Red 1LE
I'm considering the AGP dual set up with flex fuel for my build. How are the pumps controlled for boost? Is there a Hobbs switch with the kit? Also looking into the trap door option, dropping the cradle with no help sounds difficult to me. More getting it back up into the car than getting it down.
New Camaro --- 2017 SS 1LE Garnet Red -stock
Last Camaro --- 2014 2SS || 6 speed || NPP || Kooks 1 7/8 LT +Cats || Apex Catch Can || BW PTB || CAI induction || 12.99 @ 111 stock tires, 2.1 60'
Old Camaro --- 94 Z28 Vert-- Miss it.
silkrckt is offline   Reply With Quote
