Old 05-29-2012, 09:59 AM   #71
csendlak
csendlak's Avatar
Drives: 2011 Camaro 2SS/RS M6
Originally Posted by darkrider01 View Post
How are your gains set? Often, hiss is caused by too high of input voltage (the BA system radios put out high voltage). Try turning the gains down to 0 and see if they still hiss.
But the only thing hissing is the rear 6x9 that i tapped off of as soon as i connect the rca to my amp. if the voltage was too high i would expect the sub-amp to have a distortion. its almost like the input to my amp is giving off a voltage that is distorting the pre-amp line into the BA amp. . .
csendlak is offline   Reply With Quote
Old 05-29-2012, 10:04 AM   #72
Steve@Subthump
Drives: 2011 2SS IOM Vert
it's your amp feeding back. some amps need a loc or isolator
Steve@Subthump is offline   Reply With Quote
Old 05-29-2012, 10:32 AM   #73
csendlak
csendlak's Avatar
Just to be sure, are you referring to a ground loop isolator? I'm not too familiar with audio components and thats what came up when i started looking.
Old 05-29-2012, 11:03 AM   #74
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
I'm pretty sure Steve is referring to a Ground Loop Isolator or a Line Output Converter.
Also, I'm sorry - I misunderstood how you had things connected. I thought that you had hissing on your amplifier output.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Exterior Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber * OEM body kit Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Mosconi 6to8v8 w/ RCD * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-29-2012, 11:13 AM   #75
csendlak
csendlak's Avatar
No worries, in fact my bad for horrible description lol. But I'm pretty sure I have a good idea what to do now. Thanks guys, I'll pick up an isolator today and see if it fixes the issue.
Old 05-29-2012, 05:58 PM   #76
csendlak
csendlak's Avatar
ground loop isolator worked like a charm thanks again !
Old 05-29-2012, 07:18 PM   #77
Steve@Subthump
Another reason why we recommend them so much.
Old 09-13-2012, 09:41 PM   #78
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
so would this work the same on say a new 4 channel amp? I know I would have to do the X2 output side for the front and rear channels...
mgoodbar is offline   Reply With Quote
Old 07-08-2013, 05:23 PM   #79
suzook
Drives: camaro
Revivng this thread from the dead! Thanks to the OP, I saved myself $82....I had all the material needed. Took me about 30 mins taking my time...just waiting for my Basslink to arrive. THANKS OP!
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
Old 07-08-2013, 05:57 PM   #80
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
excellent read and great work...but I'm really into EASY and don't care about saving the money - and the FARK kit for a new amp from ******** makes this whole process completely plug in and done....thanks steve....
Glen e is offline   Reply With Quote
Old 11-25-2015, 01:18 PM   #81
kenny17
VILENT
kenny17's Avatar
Drives: 2013 Wht ZL454 SS/RS M6
Spliced RCA into Subwoofer Out on X1. Used White wire on X3 for remote turn on. Worked Great. Using RCA Voltage Regulator for my amp volume. I like that better because it actually mutes the amp unlike the gain remote that came with it. Thanks to Camaro5 for all the help on my new clean install.
kenny17 is offline   Reply With Quote
Old 10-22-2017, 05:44 PM   #82
Dusk_2SS
Dusk_2SS's Avatar
Drives: 2013 Dusk Special Edition 2SS/RS
There is a better way now. Same concept different pins.
http://www.camaro5.com/forums/showthread.php?t=511374
Dusk_2SS is offline   Reply With Quote
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Adding a Clutch Reservoir to Isolate it from Brake System mtcwby V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 08-22-2009 05:02 PM
Adding an Amp to the BA system... ZZcamaro Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 1 07-09-2009 12:52 PM
