#43 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
A little update
Put some miles on the new intake today. I was monitoring fuel trims and IAT.
It was about a 30 mile cruise. Still don't have enough miles put in to report accurately on fuel trims but the LTFT are coming in at about -3.9% in all kinds of driving as of now. What impressed me the most is the IAT's. It's 48 here today. When driving IAT's were at 50 degrees. Went up a little at a stand still, but quickly and I mean quickly got back to 50 when I started going again. Stock box was not even close to that. When I got home the intake was cold to the touch and I don't mean not warm or hot, it was COLD. Never have I had an intake not feel at least pretty warm. If you look through the front of the grille you can see the wide mouth of the intake having full access to outside air. It is BADASS!!! On another note, I originally did not use the long bolts to secure the radiator. I was thinking about it and so what I did was use the stock bolts only and put them back in. Not all the way though. What it does is keep the keep intake in place, but also helps stablilize the radiator. I think it is perfect AND you don't have to use those nasty looking stock brackets. Here is a couple of pics. |
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Cool. Thanks for the updates. It's a little hard to tell from the pictures, but are the stock bolts just biting on to a small portion of the intake material. What made you decide you should add something? Too much movement?
#45 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
#46 | |
Go Blue!!!!!
#47 |
Go Blue!!!!!
#48 | ||
It is definitely a better look. Quote:
#49 |
I'm planning on getting a Vararam intake very soon, a few questions though. Currently there are no mods on my Camaro but I am planning on getting headers/exhaust and possibly a cam in the future. Should I get the tune or no tune model? If I get the tune model can it be tuned to my stock vehcle then retuned as I modify the engine? If I get the no tune model can it be changed to a tune model? Thanks for the help!
#50 |
Go Blue!!!!!
Tinkered somemore with stock radiator support screws
Ok, I guess I can't leave well enough alone. However, I was thinking about the stock bolts and using them as the support guides. Since they were not screwed all the way in, at some point could they fall out? I did not want to find out. So, I added some L brackets. Had to modify them slightly, but I think it came out great. Here are some pics.
#51 | |
Go Blue!!!!!
http://vararam.com/camaro-ramair-unit2.html |
#52 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
I wonder what if any RWHP I would pick up if I were to switch from my Halltech over to the Vararam.
Hopefully a few others that have the new version will chime in here about their experiences. I also hope someone can do some dyno comparisons to see if the Vararam definately makes more power over other CAI out there. Personally I like the looks of the Halltech better but if I could pick up an extra 10+ rwhp I might have to just pull the trigger and go beyond looks for performance.
Build Journal ![]() |
#53 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
They do offer a FULL refund and will pay return shipping if you are not satisfied.... DO IT! AND DYNO IT!
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
#54 |
![]() Drives: '91 Z28, '11 2SS L99 Join Date: Feb 2010
#55 |
#56 |
I think/hope that they adressed this while designing this part
| Camaro Dove Tail Spoilers Compilation | daphatgrant | Cosmetics and Lighting Modification Discussions | 473 | 07-11-2025 10:07 PM |
| Racing Brake 2 pc Rotors Installed | mtcwby | Suspension / Brakes / Chassis | 36 | 11-13-2010 06:07 PM |
| Got A Vararam for $10! (Warning long read) | shadow09 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 04-26-2010 11:44 PM |
| Check Engine light on after ARH and Pipeline CAI installed | se7en | Tuning / Diagnostics -- engine and transmission | 17 | 03-10-2010 09:06 AM |
| Another Dealer Installed Stripe Problem | 69er | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 07-13-2009 04:32 PM |
