Old 01-20-2017, 02:28 PM   #393
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Almost 2 years here plus just installed the Z/28 headers.
Orange Krush II
Old 02-21-2017, 04:30 PM   #394
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
So I have a Z/28 CAI, Kooks 1 7/8 (Ceramic Coated inside and out), NGK Plugs (possibly not needed but runs good), Taylor 409 Wires (Mainly Color matching, I know vane). Car Ran a 400+ HP and TQ with a AFR of 12.3 on a Mustang Dyno. Can't Compare other intakes without purchasing them. Happy with what I have car runs great, have had the intake in the car for about 1.5 years now.
Ir0nM4n is offline   Reply With Quote
Old 02-21-2017, 07:03 PM   #395
mb13
mb13's Avatar
Drives: 2015 Z28 #980
Great lookin 1le
mb13 is offline   Reply With Quote
Old 02-23-2017, 09:16 PM   #396
The_Raging_Bull
Raging Bull Reborn
The_Raging_Bull's Avatar
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631
pretty sure that a roto-fab is much the same. I had one on my 2011 2SSRS.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631
Toy 2 '09 CGM Z06 3LZ
My DD: '17 Ford Mustang GT
Her DD: '14 F150 Ecoboost 3.5
The_Raging_Bull is offline   Reply With Quote
Old 02-24-2017, 10:16 AM   #397
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
HA!....Having had both it is not! (also had an SLP Blacking which I liked)
The Roto-fab is sub par. It uses a metal "heat-shield" that actual rubs on the lines coming from the radiator. There is no provision for the change in the neg. cable on the drivers front on the 2013-2015 cars. The housing for the IAT was molded in 2 parts and the tools do not line up. The parting line is very visible and they grind it down by hand.
The GM Z/28 intake is exactly what you would expect from and OEM, Fit and finish is great. There are no interference issues (clearance) and it bolts in 15 minutes with out the need to re-route of make any modifications. It has also been through durability and validation testing which no aftermarket supplier is subject to.
Very different parts!
-Matt
Old 02-27-2017, 11:32 PM   #398
maroonponyina1LE
Drives: 2015 1LE
This Z28 CAI is on my mind as a potential modification. For those that have already done an installation, are there at least some ways to install the Z28 CAI kit on the LS3 that would allow for the reinstallation of the original LS3 CAI, and also does not require drilling, etc. that would become permanent modifications to the car? While I look forward to your answers, I do want to acknowledge the installation by the owner who had the ingenuity to dream up the grommet screwed into the throttle body idea, and the skill to actually pull it off.
I do have a 1LE with the factory oil separator. Factory oil separator is not currently installed. If I do put it back on, I want a way to easily and quickly remove it, even if I did install the Z28 CAI.
Thanks in advance for your replies.
maroonponyina1LE is offline   Reply With Quote
Old 06-10-2017, 09:04 AM   #399
pabloss
pabloss's Avatar
Drives: 2010 camaro ss
So is a 2010 Ss l99 camaro complatible without any mods?
pabloss is offline   Reply With Quote
Old 03-26-2018, 07:18 PM   #400
Optimus Prime
Optimus Prime's Avatar
Drives: 2014 Chevrolet Camaro 2SS/RS 1LE
I'm the OP and I don't remember if I even came back to this thread since the very beginning! LOL I was just reading through the posts, and I really like what I've seen. A special thanks to CreeperRS for getting solid dyno numbers on the intake. Everything I've read about the changes are the same that I experienced (whooshing sound, better response, and a stronger pull at higher RPM's). I was just looking for info anyone found on the replacement filter and stumbled back on this. Thanks everyone!
Current: 2014 BRM 2SS/RS 1LE w/NAV, NPP, Recaros
Former garage: 2010 IBM Camaro 2SS/RS 6M
2011 Avalanche LT
Optimus Prime is offline   Reply With Quote
Old 03-26-2018, 07:58 PM   #401
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
....and I waited forever for you to come back in here.
mlee is online now   Reply With Quote
Old 03-27-2018, 03:00 PM   #402
Optimus Prime
That's dark.... Sorry to keep you waiting.
2011 Avalanche LT
Old 05-13-2018, 09:28 AM   #403
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I guess it’s been 2 years since I installed my z/28 intake. Never so much as a hiccup!
Moto-Mojo is offline   Reply With Quote
Old 05-13-2018, 10:25 AM   #404
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
? I can swap mine back to stock for a trip to the dealer in about 10 minutes. Did I miss something???
O.F. is offline   Reply With Quote
Old 06-27-2018, 09:27 PM   #405
67 to 91 to 13
67 to 91 to 13's Avatar
Drives: 2013 Inferno Orange Camaro 2SS/RS
I installed my Z-28 CAI tonight. I took her for a drive and at one point hit the gas pretty hard. Around 4-5k RPM’s it opened up and roared! Very satisfied. Easy install. I ordered from Summit Racing. I have to call them as I did not get a new MAF sensor with it??????
2013 IOM Camaro 2SS/RS
67 to 91 to 13 is offline   Reply With Quote
