Old 02-18-2010, 01:35 PM   #15
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
Originally Posted by AdnanHfuda View Post
i have a question kinda related but i dont want to make a whole nother thread just for this.
whats this thing called 'rpm matching' lets say im in first gear and i go up to 6000, when im shifting up what should the engine be in when i engage the next gear?? i think if the rpms are matched perfectly to the speed of the driveshaft then the shift would be smoothest
rpm matching is for downshifting (you COULD use it to shift into a higher gear, but coming from a lower gear you don't really 'match' so much as you just let the rpms come down). It's one of the premises behind double clutching. It is the SOLE premise behind shifting without using the clutch what-so-ever.
Say you're cruising at 70 mph in 6th gear. You need to pass, so you drop it down. You can go to 5th, 4th, 3rd (2nd if you should desire but that's pushing it). The RPM to go 70 mph in all of those gears is different, or rather they are all higher than the rpm going 70 in 6th gear. So say we want to get by quickly and are going to drop it into 3rd gear. Push in the clutch, push in the accelerator to get about 4000-4500 rpm on the engine, then let off the clutch. You have now rev-matched.
TommyTSquared is offline   Reply With Quote
Old 02-18-2010, 01:38 PM   #16
Wvallediego
Wvallediego's Avatar
Drives: Inferno Orange 2010 RS SS
I sometimes shift from 1st to 3rd at about 3500. I am steping on it most of the time, so I don't really notice. I don't like to loat my engine shifting at low speeds.
Wvallediego is offline   Reply With Quote
Old 02-18-2010, 01:42 PM   #17
kdbolt70
kdbolt70's Avatar
Drives: 2010 Camaro 2SS/RS
What he said. Its sometimes known as "blipping the throttle", so you don't get a lurch when you drop it down into a higher gear. IF you get the rev's up before you disengage the clutch, you're powertrain will have less to compensate for.
2SS/RS Victory Red M6 w/ Black Rallys #3305
Muffler Delete, Lloyd "SS" Floormats, K&N Aircharger, Skip Shift Eliminator, Blacked Bowties
kdbolt70 is offline   Reply With Quote
Old 02-18-2010, 01:46 PM   #18
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
great help thanks, iv been thinkin about it for a while
AdnanHfuda is offline   Reply With Quote
Old 02-18-2010, 01:52 PM   #19
Stingr69
'69 Owned Since '79
Stingr69's Avatar
I cruise between a little over 1000 RPM and 2500 RPM. Not under 1000 for any reason.
If I am over 2500 RPM it is probably for a reason. More RPM's are used when power is needed.
-Mark.
Old 02-18-2010, 01:53 PM   #20
greenrail
Comic Curmudgeon
greenrail's Avatar
Drives: 2010 Camaro 2SS-2010 VW CC Sport
My normal shift range is in the 2300-2500 range unless I am "getting on it." Once in the gear I wish to be in, i try to keep my revs low. Torque Montser has been mentioned here several times for good reason. The range of torque ont hese babies is sufficient enough to allow decent acceleration from lower RPM's.
Having said that, I tend to drive for economy whenout on the highway. Yeah, I love the power, and use it when appropriate. (Which is a very subjective criteria.- Basically when I need a speed rush.)
It is basically how I can achieve 26.8 mpg on many of the Interstates around here.
Member Illinois Camaro Club
His Name is Rosie - "Speak Softly and Carry a Big Stick!" - If you know who said that, then you know the genesis of his name.
greenrail is offline   Reply With Quote
Old 02-18-2010, 01:55 PM   #21
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
Originally Posted by Moriartii View Post
What is the general consensus for manual shifting rpms? At what point do you shift to the next highest gear and what is your optimal rpm range for the current gear you are in?
Example:
I usually shift to the next highest gear at about 3000 -3200 rpm and I usually stay about 2500 - 2800 for my current gear rpm.
Cheers
K
It depends on wether or not I want to let my neighbors sleep. (Muffler Delete)
MikeSVX is offline   Reply With Quote
Old 02-18-2010, 01:57 PM   #22
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
Originally Posted by Dack View Post
I'm with him. Same shift points.
chrisgalles is offline   Reply With Quote
Old 02-18-2010, 01:58 PM   #23
MikeSVX
MikeSVX's Avatar
Originally Posted by franknbeans View Post
I always shift above 23-25k just so I don't get the 1st to 4th skip shift.
Holy Crap 23 to 25K!! You got a turbine engine? J/K
Old 02-18-2010, 02:51 PM   #24
xtreme industries
Drives: 2010 Camaro 2lt RS
i shift around 4-4500 rpm when accelerating but will cruise around 3000rpm. i find the v6 a little lethargic below 3000 rpm. i have no use for 6th gear.
xtreme industries is offline   Reply With Quote
Old 02-18-2010, 03:12 PM   #25
PB3
PB3's Avatar
Drives: 2010 CGM 2LT/RS/GFX/M6
Interesting
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
PB3 is offline   Reply With Quote
Old 02-18-2010, 03:42 PM   #26
2Muchmark
2Muchmark's Avatar
Drives: 2013 2SS RS 1LE
Send a message via ICQ to 2Muchmark Send a message via MSN to 2Muchmark Send a message via Skype™ to 2Muchmark
What everyone else said (Shift around 2500-3000, cruise around 1500). Feels good, tastes great.
2Muchmark is offline   Reply With Quote
Old 02-18-2010, 04:52 PM   #27
rudack
Rudack
rudack's Avatar
Drives: ABM 2SS/RS
Send a message via AIM to rudack Send a message via MSN to rudack
2500-3000 just like the others.
ABM 2SS/RS #33390
rudack is offline   Reply With Quote
Old 02-18-2010, 05:00 PM   #28
brtaus
brtaus's Avatar
Drives: None
I try to shift around 3000-3500 RPM's; normal cruising RPM is around 1800-2200
brtaus is offline   Reply With Quote
GROUP BUY- Mach XL V6 (Manual) and Mach XLT V6 (Automatic)- Ends 11/30/09 GOINGSOLO2 V6 Bolt-Ons & Tunes 252 10-20-2011 09:33 PM
Not So Smooth Shifting 69er Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-19-2010 08:01 PM
Stupid question yay should i get ls3 if i dont know how to drive manual yet thejoker1232 5th Gen Camaro SS LS LT General Discussions 29 10-22-2009 02:39 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
