#43 | |
ROCK
Drives: 2013 ZL-1 TRIPLE BLACK VERT Join Date: Oct 2012
CAM/JRE IS A BIG HELP
I HAVE TO AGREE AS TED AND AL HAVE BEEN GREAT TO ANSWER ANY QUESTIONS I HAVE HAD EVEN BEFORE I BOUGHT FROM THEM.NOT MANY COMPANIES GIVE AWAY INFO WITH OUT YOU BEING A CUSTOMER. PLUS ALL THE TECH WORK TED HAS PUT INTO THE ZL1 IS AMAZING. I WILL CONTINUE TO BE A CUSTOMER FOR A LONG TIME. THE 75 RWHP KIT WORKS AS ADVERTISED!!! I SPENT 35 YEARS IN THE AUTOMOTIVE AFTERMARKET AS A SALES AND TECH REP. LAST GIG WAS WITH MOOG AUTOMOTIVE OUT OF ST. LOUIS...BEST CHASSIS PRODUCTS ON THE PLANET...JUST ASK ANY NASCAR DRIVER/CREW CHIEF.
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
#44 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
#45 |
Drives: 1987 Buick Regal Turbo-T Join Date: Sep 2009
Incorrect. We actually have our cams done by a prototype camshaft manufacturer. Not a crane, comp, lunati, or any company anyone would have ever heard of. Why? because they can make cams to our spec. Not saying any other cam company does a bad job, but when we want full design control of our lobes, they can do it, without the fear of anyone copying. They do this as a courtesy to us, as they are not a performance company. They are a place that the OEM's would call when they need a cam for an engine that does not exist yet, so their capabilities are literally endless for what they can make.
#46 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Oct 2011
so do they just cut of of a billet instead of using a blank? this is one thing I have always wondered not that so many shop use there own specs you don't really know the path of how the cam was manufacterd or quality level. The volume is so much lower quality could be better or worse depending on who does the work.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
#47 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Is that a fact or an assumption on your part? |
#48 |
what do you mean. the fact that tunning shops use other suppliers to manufacture there cams?
as far as I know almost all of them use a 3rd party supplier or suppliers. Jannetty stated he uses comp. livernois stated they use a cam prototyping vendor. or that qualtiy can vary bettween suppliers? that is just nature of business. I see that all day every day at work. Due to huge lead times in avaition we can have parts made at multiple shops. we have prefered suppliers for a reason.
#49 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: C7 / ZL1 / SS / trucsk Join Date: Nov 2009
People take a chill pill, I'm the knoob when it comes to mechanics and wrote the wrong statement and JRE was just trying to clarify!
I wrote made in house vs Livernois Motorsports corrected it , I just knew the CAMs they used were unique to them! Both are top notch companies !
2014 C7 Stingray 3LT/Z51
2013 Camaro SS 2012 Camaro ZL1 - 850 HP 2015 GMC Denali 3500HD 4x4 2012 GMC Sierra 3500HD 4x4 |
#50 |
![]() Drives: 2012 CHEVROLET CAMARO ZL1 (BLACK) Join Date: Aug 2011
Sorry guys. I haven't been able to get on here lately. I've been busy with work but I do appreciate all your responses and opinions. Thank you all.
#51 | |
![]() Drives: 2022 Camaro ZL1 Convertible A10 Join Date: Aug 2012
The rough idle clears up once the car gets underway. If I go through the time and expense to install another cam Then, I want to hear a rougher/lumpier cam idle than stock or LS9. ![]() |
#52 |
![]() ![]() ![]() Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
Good thread, so I thought I bring it back to life. Seems like the Brian Tooley Stage III is the hot cam right now. What other custom grind cams are you guys running now a days?
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 |
#53 |
I have a line of cams specifically for the LSA engine in the ZL-1 and CTSV.
They are designed for the rigors of Road racing so they will last as long as the engine. They are very easy on parts and make incredible power at low boost. 650 RWHP at only 11.5 psi boost on 93 octane and 680 RWHP on 96 octane with our tuning. Ted.
Thread Tools | |
