#43 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
You got that right, 22 is ooof kinda cold, I got all your stuff together and will be leaving Friday night, so sometime on Saturday morning until noon we can meet or I can drop it off.
I text you tomorrow. |
#44 | |
![]() ![]() Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
#45 |
Mini split is in and running perfect!. 26 degrees this morning, and the garage was right where I set it at 68 just cruising.
Thanks to all of you for the advice! And special thanks to @Infidel67 for the use of his flaring tools and pump. Awesome family we have here. ![]()
#46 |
![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
Nice job. I heat my garage with a patio heater. Does the job for me when i need it.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
#47 | |
Life's just a Ride
#48 |
This is awesome! Will make winter a lot nicer for you lol!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
#49 |
Yes sir. Working this past weekend in the garage in a t-shirt was awesome!
Thread Tools | |
