08-29-2014, 08:18 AM | #71 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
I didn't take any pictures, but the area is indeed blasted there from the factory. No, I have not noticed any issues with sliding or rotating, but I also don't have the Carbon Ceramic brakes. I have the CTS-V 6-pistons. I ran the car very hard at private retail at Gingerman this past Monday and even had a 40 minute session that I burned a 1/2 tank of gas. The front calipers are now a gold color (because of the bunk clear coat reacting to the excessive heat).....But tires are still in balance as I drove the car home instead of towing it. -Matt
08-29-2014, 08:27 AM | #72 |
ace5.org (Atlanta Club)
Drives: 2010 Black/IOM 2SS LS3 Join Date: Sep 2013
I don't know if you sold the CTS-V Recaro seats or not yet, but if you haven't I would suggest putting them on ctsvowners.com I'm sure you would get a lot more interest there.
08-29-2014, 11:19 AM | #73 | |
-Matt
08-29-2014, 11:29 AM | #74 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
So if you have now had the car on the track with the Z/28 wheels do you have any thoughts/notes to summarize the differences after the wheels were added? I'm very curious to hear your results!
08-29-2014, 03:21 PM | #75 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
I have the forged ZL1/1LE wheels that I have street tires mounted on (DSW) I run the GY F1 285 on FR 10x20 (allows me to be able to swap front to back easily) I was thinking about blasting the bead area on the FRs the next time I change the GYs out. a couple of things: not sure if tire slipping on the rim is really an issue for me (I too added the CTS-V calipers and 2 piece rotors) I marked the tires at the stem location and they moved, but not sure if they moved several rotations or just a little. the FRs are very smooth in the bead area, I would think once they got hot they would really stick to the rim...... the tires do shake a bit after running them for a weekend, but not excessively if it was easy and I do not "over blast" the bead areas on the rims (do not want to make it so rough that they do not seal) I might give it a go just because I can do you recall what the surface looked and felt like? 120, 220, 400 grit sandpaper as a reference? this would help decide what media to blast with. oh BTW, I am running between 33/35 psi hot in the GYs
09-01-2014, 06:49 PM | #76 |
Drives: 2011 Camaro SS Supercharged Join Date: Sep 2012
Great build, congrats on COTW!
09-01-2014, 09:27 PM | #77 |
OFF THE CHAIN
Congrats on COTW well deserved~
09-01-2014, 09:46 PM | #78 |
Jan
Drives: 2010 Camaro 1LT Red Jewel tintcoat Join Date: May 2010
Congrats on COTW! Awesome thread & build. I know it is unlikely but I would be thrilled to find you hauled that bad boy down to Bowling Green, KY this next weekend for the LS Fest! If you by some lucky turn do so, Look up Ruby! I'll be keeping an eye on you.
09-02-2014, 05:02 AM | #79 |
Drives: 2017 Jaguar F Type R Tuned 498awhp Join Date: Apr 2013
Congratulations on CAMARO OF THE WEEK! Well deserved with the beautiful car and great help you have been to many of us on this forum. I bought my CTS-V brakes because of your thread!
So many thanks!
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
2017 Jaguar F Type R ''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller |
09-02-2014, 05:17 AM | #80 |
Drives: '16 C7 Z51 Join Date: May 2012
This actually looks pretty good; which model are they? At 22.4 lbs, TSW Nurburgrings 19x10.5 ET27 are also lighter than Z/28 wheels. Do you have more pics you could share so we could see the clearance and/or how much they stick out? This might be a great track set-up.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
09-02-2014, 06:12 AM | #81 |
No Tags/Habitual Violator
Drives: 2012 SIM 2SS/RS & z71 Join Date: Sep 2011
Congratulations to Matt on COTW (recognition has been long overdue)
09-02-2014, 10:01 AM | #82 |
Drives: SS,PaceCar,ZL1,1LE,C7Z51,Z06,17-ZL1 Join Date: Jun 2009
Congrats Matt!! It's a privilege to have been
a small part of you COTW!! Thanks again for all you do to share with everyone here. And THANKS ALOT for the track addiction - this it getting expensive but SOOOOO fun!! |
09-03-2014, 07:31 AM | #83 | |
-Matt
09-03-2014, 07:40 AM | #84 | ||||
Thank you!
Thanks! Quote:
Thanks again everyone!!! Matt
Thread Tools | |
