Old 04-28-2025, 03:31 PM   #1
slphawk
Drives: 2011 Camaro SS Conv. 1994 Firehawk
How do you use the convertible top manually?
I see that there is a allen wench, but where exactly does it go?
2011 Camaro 2SS.
slphawk is offline   Reply With Quote
Old 04-28-2025, 03:55 PM   #2
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
https://www.camaro5.com/forums/showthread.php?t=556768
here you go, locate the pump, release the pressure
and do you have an SLP version?
MSgt O is offline   Reply With Quote
Old 04-29-2025, 07:04 AM   #3
slphawk
Thank you!
Old 04-29-2025, 09:50 AM   #4
MSgt O
MSgt O's Avatar
hope it helps! good luck and youre welcome!
Old 05-01-2025, 12:53 PM   #5
slphawk
I found out that there is a small "door" on the top of the back seat, after it is open there is an allen bolt that can be turned for manual operation with GM part number 22772402. The GM wench is discontinued, but some are available on ebay.
Old 05-01-2025, 09:22 PM   #6
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Turn it counter clockwise no more than 1 turn. Your car should have came with the wrench, but I know how those things can go. After power is restored, you can tighten the bolt clockwise with the wrench. If the battery was disconnected, you need to re-program the windows for the convertible top to work using the button.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 05-02-2025, 12:41 PM   #7
MSgt O
MSgt O's Avatar
https://www.camaro5.com/forums/showthread.php?t=218308
so i just found this with the instructions and all!!
