Old 06-19-2019, 05:05 PM   #1
mactube
Drives: 2015 Camaro Convertible
How to I replace the top cylinder ? (Hydraulic Pump)
Does somebody have experiment on how to get to the cylinders which drop the top? I have seen some youtube videos .. but only on there cylinder repairs on mustangs.
The cylinder on the passengers side will have to be replaced since its " dragging "
Thanks in advance..
mactube is offline   Reply With Quote
Old 06-22-2019, 09:25 AM   #2
DaddySS
Kept The Faith
DaddySS's Avatar
Drives: 2011 Camaro SS Convertible
From the repair manual:
2011 Vert - 2SS/RS 6spd Triple Black
DaddySS is offline   Reply With Quote
Old 06-28-2019, 01:13 AM   #3
mactube
Wow @DaddySS thanks you so much for the detailed plan !
I will let you know how it worked out!
Old 07-02-2019, 07:49 PM   #4
mactube
@DaddySS I have gotten to the the bad cylinder and was able to take it off but then hesitated to proceed when I saw the hose attached to the cylinder. Since the cylinder and the hose are very hard to access I hesitated to proceed since I was not sure if I would be able to get the hose back on the new cylinder and the oil properly refilled. So I decided to bring it to a upholstery show that I found which has done that kind of work before. The shop installed the new cylinder for $150 , but now the other side is a little slower. I will have to bring it back to the shop so they can service the system .. my be to little hydraulic oil !?
Thanks for the Diagram though !!
Old 08-09-2019, 03:45 PM   #5
mactube
Just to close this thread and maybe give somebody an idea of the kind of repair that has to be done if somebody experiences the same problem " one side of the top " dragging" slower than the other one" Which could be because of different pressure in the oil lines due to air in the oil lines or in my case a bent cylinder arm of the hydraulic cylinder as here in the picture.
( Which is actually a picture of the opposite side from where the trop was dragging at first. So after that side was replaced, the cylinder on the other side was dragging and looked like this: )
[URL="https://www.dropbox.com/s/tpc5cl2pxn83c4l/IMG_08721.jpg?
