05-02-2023, 08:19 AM | #169 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
The lense will not fall forward. It is perfect fit and sits in. If it does, it's easy to grab. The lense has its own bracket that the stock mount sits on.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
05-02-2023, 08:48 AM | #170 | |
05-02-2023, 09:25 AM | #171 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
So with all that has been said… will the front bumper cover need to come off to remove the headlights in order to get the oem components out and put in the new? Or can this be done while headlights and bumper cover is still on the car? Sent from my iPhone using Tapatalk
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
05-02-2023, 05:49 PM | #172 | |
05-02-2023, 05:58 PM | #173 | |
05-02-2023, 05:59 PM | #174 |
It would be much easier if you remove the bumper cover. Otherwise loosing screws, dropping parts tools etc.
05-03-2023, 08:25 AM | #175 | |
https://www.google.com/search?q=fron...id:WdVL4fv9IVk |
05-03-2023, 09:48 AM | #176 | |
05-03-2023, 02:43 PM | #177 | |
UPDATE- got the brackets today. Quality workmanship, even comes with nuts,bolts & washers to attach the bracket and projector. Based on the smallness of the bracket’s washers & nuts even with the wheel removed I don’t think it feasible to install the bracket without removing the bumper. In order to attach the bracket you’re going to need to tilt the headlight to prevent the washers & nuts from falling into the headlight cavity. Even then they’ll probably fall but with the bumper on you’ll have no chance to get them if working from the wheel well. Oh well at least the headlights don’t need to be baked open Last edited by camguynj; 05-04-2023 at 10:56 PM. |
05-04-2023, 04:16 PM | #178 |
Drives: '11 2SS/RS M6 Join Date: Dec 2010
Got my bracket yesterday
05-04-2023, 04:40 PM | #179 | |
Great! Looks like I am going to try this first before removing the front bumper cover again. I have a custom belly plate on my car pretty much like the ZL1’s do so this is another step in the process of removing the bumper which is a PITA but doable. Thanks for sharing the link. Sent from my iPhone using Tapatalk
2010 2LT/RS
05-04-2023, 04:41 PM | #180 |
I received mine as well Sent from my iPhone using Tapatalk
2010 2LT/RS
05-04-2023, 10:55 PM | #181 | |
05-05-2023, 09:40 AM | #182 |
Bumper pulled and lights removed. I didn't even take the wheels or liners off. Half hour or so. I'll do my best tdor a write-up tonight on disassemble and reassemble for y'all.
These things are amazing in quality and they fit fantastic. This is the BS I found that ks to cheaping out on reflection bowls. Literally flaked and melted nearly through
