#2073 |
![]() Drives: 2010 IOM SS/RS Join Date: Feb 2013
You sir are a Psychopath!
Good Job is an understatement ![]() |
#2074 |
SoCal Race Team #13
Amazing work by many people (on nathans car, and others).
Here is what I've been working on... Did aluminum first to make sure the CAD files are valid. In aluminum they save 1.6 lbs. I have a sheet of carbon fiber thats going to the waterjet next month, I will post up weights on that too... Factory bracket & screws (no solenoids) = 1.5 lbs each side Aluminum bracket & screws (no solenoids) = 0.7 lbs each side ![]() It mounts to the factory covers and utilizes the factory wiring (both solenoid wiring, and spark plug wires). ![]() ![]() Now, I just need to pull off the factory valve covers, remove the extra mounting holes, and polish them up. Also going to go ahead and polish up the brackets (they are t6060 and should shine).
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC |
#2075 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
I am sorry, but I don't approve of the upside down coils, isn't something else you can do?
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
#2076 | |
Drives: G5.R Join Date: Sep 2010
Stache that's pretty innovative. I see like Doc, your also into getting rid of as much weight as possible. Can't wait to see the final rendition! Might pick up an idea or two from you. Thanks for posting! ![]() More updates on the suspension thread: http://www.camaro5.com/forums/showthread.php?t=285800 WHAT....... Last edited by Moreno1; 05-11-2013 at 12:40 AM. |
#2077 |
Looks AWESOME Nathan!! Balls and a Sawzall !!! LOL
Dont forget to look for those lines for me...i need them badly ![]()
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11 RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453 SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/ |
#2078 | |
#2079 | |
knows 2 facts about ducks
#2080 |
RJ, I'm sure there is another solution for FM radio.
BTW Guys, I wanted to post this exert from an e-mail Larry at TechAFX sent me. Some folks had recommended using these QD fittings earlier on this thread. I looked over the earlier stuff in that thread & I would warn ANYBODY about using this piece of sh*t: ![]() It's an unsafe, under-engineered, cheap, Chinese made, piece of junk. The U-shaped bit doesn't secure well & can vibrate loose. One of the principals at SDPC had it loosen up on his Corvette & only by the grace of God did he avoid an engine fire when the fuel sprayed out. Finch wasn't as lucky as his old Camaro burned to the ground because of one of these run between the trans. It leaked when he was out track racing. He now runs a 71 Camaro. Tales of these things failing are all over the place. That's why we make these QD Jumpers, so our customers can SAFELY upgrade their cars. |
#2081 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
#2082 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
#2083 | |
New updates in the suspension thread: http://www.camaro5.com/forums/showth...=1#post6544599 Received the new Flex-a-lite radiator yesterday. This is the original one I got from Flex-a-lite that's designed for 5th Gen Camaros. Being that we are tucking the rad forward and under the rad support, it would have necessitated several modifications to do it like we wanted. It made more sense to just get a new one rather than modify the existing one. This is the original rad that is going to Synner. I'm glad I was able to hook him up.
#2084 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Anniversary 2SS Join Date: Mar 2012
#2085 |
Hi everyone!
Just wanted to introduce myself.. some of you may know me from the pictures, I am Justin, Nathan's brother. Nathan suggested that I make an account here to post along in the project threads, so I did ![]() I will try to help Nathan out a little bit by helping with the project updates, asking/answering questions, and just joining in on the fun here! I have followed this thread as everyone has been posting so I'm familiar with all of you regular addicts LOL. It will be fun hanging out with you all. ![]() Justin |
#2086 |
Dances With Mustangs
Welcome Justin! It's good to know somebody is there with Nathan in case he goes overboard and does something extreme.
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ | AutoAgenda | Exterior Parts & Accessories | 14 | 02-06-2013 08:43 PM |
New Texas Speed & Performance Engine Machining Center! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 01-16-2013 03:46 PM |
Hawk Performance Brake Pads part HB247Z.575 $85.00 | Rogan | USA - Florida | 2 | 10-07-2011 12:10 PM |
Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
