#15 |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
I've been a tech for almost 10 years and never had a socket stick to a lug. And I know the torque of every lug I've tightened with my impact within 5-10 ft lbs. And I've never damaged a wheel.
#16 |
![]() Drives: 2013 Camaro SS 1LE Join Date: Jul 2013
i could walk outside and make the key socket for my gorilla lug nuts seize on it right now, thats why i dont use it....5-10 would be impressive considering my ingersol rand impact is only adjustable in 50ish lb increments, what impact is adjustable in 5lb increments? hey if hand torquing is good enough for Ferrari its good enough for my 1LE, mostly because i can actually afford a 1LE
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 1LE Join Date: Jul 2011
#18 |
#19 | |
![]() Drives: 2013 IOM 2SS 1LE Join Date: Aug 2013
If you snugged it up with the impact and then torqued to spec you would have done it correctly. The lugnut doesn't know if it is on a Chev, ford or Ferrari, they should all be torqued.
#20 |
Banned
Goodyears from Discount Tire
So using a torque stick/impact is the wrong way? Lmao. Its the flat rate way. And its also the best way. No calibration is ever required on a stick. It just works the same way every single time. You guys are acting like using a impact totals the car. It's a little crazy. It's a Chevy. It's not a high end car. These camaros are not collectible nor will they go up in value. They are Chevys and super common cars. You people need to calm down. That's why I love this forum. It's always great for a laugh.
#21 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
Here is a little torque stick 101 for you: A torque stick is used with an air impact wrench to avoid over-tightening fasteners when installing wheels. Torque sticks work by flexing (like a torsion bar) when a torque limit is reached. When the stick flexes, it resists further tightening of the fastener. The thicker the torque sticks, the higher the torque to the fastener. Torque sticks are useful, but they are no substitute for final torquing using a calibrated torque wrench. The proper procedure for using a torque stick begins with hand-tightening the fasteners. Then use the proper torque stick on an impact gun to tighten the wheel until there is tension on the fasteners and the wheel pulls up tight. Lightly go over the fasteners again to tighten them a little more. Then tighten each fastener again until it stops moving. Then drop the vehicle to prevent the wheel from turning and use a torque wrench to do the final torquing. There are some very important cautions when using torque sticks. First, they should not be used to get to anywhere near final torque. Select a torque stick rated for about 2/3 of the final torque and then finish the last 1/3 of the specified torque with a torque wrench. If the fasteners don’t move with a torque wrench before the click for final torque, there is a problem or the fastener has been over-tightened. Many techs don’t realize that torque sticks are designed for a limited range of torque input. They must be used with an impact wrench, and if an impact tool with too high, or too low, of a setting is used, the torque stick will still over-torque the fasteners and may cause damage. The impact gun must be set to a specific torque range and the air supply and pressure must remain constant. Also, different torque sticks often will require different impact wrench settings. It is unrealistic to expect a wrench/torque stick combination to be accurate without checking the impact wrench setting. An impact wrench can be calibrated by first using a torque wrench to tighten a nut to the torque that matches the torque stick. Then, connect the air supply to the impact gun using an air regulator with repeatable settings. While using the torque stick, increase the air pressure to the impact wrench until the nut just moves. Reduce the air pressure slightly, and then tighten another nut. Verify the actual torque on the second nut with a torque wrench. FYI: Many Camaros have gained value over the years.....it just takes 30-40 on average. -Matt
#22 | |
I'm running out of time today so I'll probably head over there tomorrow morning. A little googling turned up a company they contract with to fix such disasters. AWRS Wheel Repair claims to handle this for Discount with their mobile service. It's completely unreasonable to demand replacement since it's on the inside of the wheel but since you can see it directly, brining in somebody to sand those out and repaint the inside rim of the wheel is expected. I'll let you know how it goes. |
#23 | |
#24 |
Thanks for the information Dropspeed.
#25 |
#26 | |
#27 |
N/P. But I didn't write all that. I grabbed it from a reputable website.
#28 |
![]() Drives: 14 1le Join Date: May 2012
Discount will fix the wheel. A good friend of mine had a set of forgelines and they scratched it and bought him a new wheel.
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold 06 Z06 500 rwhp sold 10 2ss ERL 427 530 rwhp sold 14 1ss 1le |
